Nismo Titanium Shift knob!!
Old May 11, 2009 | 12:45 AM
  #31
]\[ /-\ ]\/['s Avatar
looks good!
couple of questions....
does the **** get too hot in the sun to touch?
and does it sit shorter than the OEM ****?
Old May 11, 2009 | 01:29 AM
  #32
Weiboy718's Avatar
Weiboy718
Originally Posted by Goonz
had the dealership do it, well I told them to loosen the stock **** and the rest ill take care of. They said they would charge me $30 or so to do it with no guarantees that the stock **** wont rip. Well it didnt rip AND they never charged me for it!
oh! i thought you did it yourself!!!
i have a good tip to remove the shifter without ripping it if anyone needs it!
Old May 11, 2009 | 11:40 AM
  #33
Goonz's Avatar
Goonz
Originally Posted by ]\[ /-\ ]\/[
looks good!
if your car is baking under the sun then yes it will get hot, but it will cool down once you have your grip on it and the AC is on..I also think that since its a little smaller in diameter from that of the stock ****, it sits just a tad bit shorter..
Old May 11, 2009 | 11:48 AM
  #34
hispeed-lowdrag's Avatar
hispeed-lowdrag
please share with us!!!
Old May 11, 2009 | 12:14 PM
  #35
madmax2k1's Avatar
madmax2k1
Does the shifter feel super hot during hot/sunny days?
Old May 11, 2009 | 12:21 PM
  #36
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
Share the love man. Whats the tip? Im pretty sure we all want to know.
Old May 11, 2009 | 01:55 PM
  #37
G37S-PR's Avatar
G37S-PR
The nismo look really nice. How do u damage your stock one?? Looks like some dog chew it.
Old May 11, 2009 | 03:36 PM
  #38
oOmikeyboy's Avatar
oOmikeyboy
It gets kinda hot, but it cools off very fast. Heres a pic of the old compared to the new, and height difference.
I messed the stocker up by taking a monkey wrench to it.. lmao.
Old May 11, 2009 | 07:20 PM
  #39
Goonz's Avatar
Goonz
read above posts
Old May 11, 2009 | 07:40 PM
  #40
vinnys coupe's Avatar
vinnys coupe
wieboy how did you remove yours without any damage? DIY ?
Old May 11, 2009 | 09:48 PM
  #41
lakers8's Avatar
lakers8
did you chew on that thing
Old May 11, 2009 | 10:47 PM
  #42
GiGGaplease's Avatar
GiGGaplease
is it just me or that nismo **** looks weird looking in a bad way. hah.
Old May 11, 2009 | 10:52 PM
  #43
Weiboy718's Avatar
Weiboy718
sorry guys! just got home. here's the tool's i used to remove my shift ****
1 inch radiator hose
vise grip
belt oil filter remover
second person
ok, first put your hand onto the shift boot and then pull up towards you. then you'll see a zip tie that's tied to the shifter. cut it! i think there's a foam or cotton in there also, just work your way around it. grab a razor knife and cut the hose for a opening so you could wrap it around the shifter.(beneath the shift boot) then grab the vise grip and clamp onto the radiator hose as hard as possible. then use the BELT oil filter clamp to do the turning on the ****.
the belt clamp has no teeth and doesn't slip. just watch out for the metal handle while clamping. it worked for me so it should work for everyone else. give it a try. highly recommend another person helping out. hope this helps!
Old May 12, 2009 | 04:12 AM
  #44
Goonz's Avatar
Goonz
thats just your mind
Old May 12, 2009 | 04:56 AM
  #45
elite's Avatar
elite
gigga doesn't thinks it's big enough to sit on.
