Help LED swap
Old Feb 5, 2009 | 10:11 PM
CHEFONE's Avatar
CHEFONE
LED swap
Yah I was wondering if anyone knew how to remove the plastic covering for the interior door panel light bulbs so I could swap them out for LEDS!!! Any help will be useful thank you!!!
Old Feb 5, 2009 | 10:14 PM
HamstersG's Avatar
HamstersG
Just take some firm and smooth (tape covered screwdriver) to get it started. They pop straight out. First one is nerve racking. After that it is a 10 second job. There are some threads showing pics. Search LED.
Old Feb 6, 2009 | 07:51 AM
XMMAN's Avatar
XMMAN
pop the bottom side out first then slowly pull it out..then remove the clear lens from the housing and pull out the bulb.. it helps if you disconnect the power wire as soon as you get the housing out so that the bulb doesnt get to hot.. there is a video in one of the threads about leds around here..
found it http://s60.photobucket.com/albums/h2...0222008064.flv
timc00k
Feb 15, 2017 09:15 AM
Upscale Speed
Dec 26, 2015 08:45 AM
ck1109
Oct 15, 2015 11:06 PM
Landshark
Sep 29, 2015 11:20 PM
