window opens when door opens....?
I don't know if my G is supposed to do this but everytime I open the door the driver side window goes down a little, then when I close the door it goes back up... is this normal? I'm thinking about taking it to the dealer for that, plus they owe me a FREE detail since my car arrived with scratches and plus the rubber gasket on around my sunroof overlapped and is twisted.
It is because the car has frameless door windows -- like a convertible.
The windows are tucking into the door seal on the A-frame of the car when you close the door. Some cars just have the glass smash up against a seal on that part, our cars just have a slightly better (if not a little more failure-sensitive) solution.
This way is easier on the glass, provides a better seal, and is harder for thieves to pry open than the mustang-style glass-smashes-the-pillar-seal way.
Yea, push the ignition button twice without pressing the clutch in... Your car should be in the "on" position... Should be able to roll'em up... Push it one more time to turn it to the "off" position (again, w/o pushing in the clutch)...
manual is in the trunk...... i thought the same thing i was like wtf wheres the manual then i found it in the trunk(i looked in the glove first)
some salesman you got. sunroof is seperate from the windows. so it won't close/open w/ the key in the door if you use it that way.
DOMO
