Seat synchrinuzation
Old Sep 4, 2008 | 07:52 PM
I never knew about this until last week when I had to look in the manual to see how to reset my seat memory after disconnecting the battery!
Originally Posted by Owner's Manual
SEAT SYNCHRONIZATION FUNCTION
The seat synchronization function automatically
adjusts the positions of the steering wheel and
outside mirrors when the seat is adjusted using
the power seat switches.
However, the steering wheel and outside mirrors
will not move if the seat is adjusted over
the maximum thresholds. The system considers
that the steering wheel and outside mirror
adjustments are not necessary because the
seat may not be adjusted for the driving position.
Note that the function is set to disabled as
the factory default setting.
The seat synchronization function operates under
the following conditions:
c The ignition switch is in the ON position.
c The selector lever is in the P (Park) position
(Automatic Transmission models) or the
parking brake is applied (Manual Transmission
models).
c The seatback is raised (Coupe).
If the outside mirrors or the steering wheel
reaches its maximum adjustment, the function
is automatically disabled. Restart the function
by selecting a previously stored seat memory
position using the memory switches (1 or 2). An
Intelligent Key that was previously linked to the
stored seat memory can also be used to restart
the function.
If a seat position was not previously stored in
the seat memory, restart the function by adjusting
manually for your best driving position and then
drive the vehicle above 4 MPH (7 km/h).
Am I the only one who didn't know?
Old Sep 4, 2008 | 08:05 PM
EZDozzit's Avatar
EZDozzit
No Soliciting
I knew
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
RexHavoc
Oct 2, 2015 11:47 AM
Bennyjoel
Sep 30, 2015 11:56 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
