roof overlay!
Old Aug 20, 2008 | 10:18 PM
jintung007's Avatar
jintung007
roof overlay!
Hi , ,
im planning to buy roof overlay kit,
but i have a question , i think, i have to take off the antenna from the roof
to install overlay kit.
so before do that i wanna double check , is anyone had a problem when you guys take off it and put it back? like radio is not working or something else.
please answer me, so i can solve this problem.
Thank you guys!
Old Aug 21, 2008 | 04:08 AM
jnguyen's Avatar
jnguyen
Originally Posted by jintung007
Hi , ,
Thank you guys!
get some bats overlay and i dont think you have to take the antenna off?
Old Aug 21, 2008 | 08:57 AM
Kidcane's Avatar
Kidcane
Florida G Club
Its just a cover and it pops right off. You can mold the overlay to cover the antenea but I think most have just cut it out and bought a black antenea cover.
Old Aug 21, 2008 | 12:11 PM
vinnys coupe's Avatar
vinnys coupe
its cut into two pieces so that you dont have to remove your attenea..but ide recommend you to get the blk attenea piece
Old Aug 21, 2008 | 01:30 PM
dvalle's Avatar
dvalle
Do you know where one would be able to find the antenna cover for cheap or the part #?
Old Mar 16, 2010 | 09:03 PM
Namir's Avatar
Namir
I know this is an oldd thread but I've searched and I can't find any way to remove the shark fin antenna. Does anyone know how to do this?
Old Mar 16, 2010 | 09:28 PM
JMacsG37's Avatar
JMacsG37
I heard it is just a clip keeping it on. There isn't a process in the service manual on how to take it off, I'm sure it is too easy for steps.
Old Mar 17, 2010 | 03:50 AM
bat6wc's Avatar
bat6wc
so what does it look like without the shark fin cover? whats left?
Old Mar 17, 2010 | 10:47 AM
WhosUrBuddiee's Avatar
WhosUrBuddiee
It looks like a big hole in your roof.
Old Mar 17, 2010 | 10:50 AM
WhosUrBuddiee
I strongly urge against the blue batmobile kit. He sells a 2 piece kit and it leaves an ugly line down the center of your roof.
Best bet is actually paint, looks better and is actually cheaper.
But if you want vinyl look in the yellow pages for Vinyl sign shops. They usually carry black vinyl wide enough to cover your roof and can install it for you. But keep in mind install for a vinyl roof will normally run about 150 dollars.
Old Mar 17, 2010 | 11:03 AM
WhosUrBuddiee
Also it is very simple to take the atenna off.
1. get in the back seat
2. grab your head liner edge by the back window, and pull down. It is only help up with velcro and acouple clips
3. unplug the XM wire
4. use a cresent wrench and unscrew the single nut
5. give the atenna a little push and it will pop out the top.
Old Mar 17, 2010 | 11:16 AM
bat6wc's Avatar
bat6wc
thanks!!!
Old Mar 17, 2010 | 03:42 PM
Namir's Avatar
Namir
Many many thanks buddie! I finally found the answer I was looking for.
I have a sheet vinyl 48" wide so it will be one piece but the antenna is a pain to try to wrap around.
It should be much easier with the antenna removed.
The antenna assembly has a cover to, it can be bought in black for 32 dollars.
Infiniti Parts USA - Your #1 Source for Factory Infiniti Parts & Accessories
Old Mar 17, 2010 | 05:35 PM
Ivoidwarranties's Avatar
Ivoidwarranties
Where did you get that info? Why didn't you tell me it was that easy six months ago?
Here is the kicker: that nut in step 4 is a 21mm nut I think. It took me a good long while to get a big cresent wrench in there to loosen that nut. After I had the top painted, my paint and body guys wanted me to put the antenna back on so they could see it finished. I told them I need a lot of time and the problems I had to work with. My buddy pulls a stubby cresent wrench out of his tool box... Freakin' awesome!!! Made things so much easier.
I found one here but they are out of stock.
Performance Tool W30702 - Performance Tool Stubby Crescent Wrenches - Overview - SummitRacing.com
Old Mar 17, 2010 | 05:43 PM
Ivoidwarranties
They just put this up so I'm going to order it and see how wide it opens.
Performance Tool W9108 - Performance Tool Stubby Crescent Wrenches - Overview - SummitRacing.com
