OEM Spoiler & Rear Deck Panel Now Available
No Soliciting
Max, my understanding is that if you only order the "Rear Parcel Shelf Finisher" as Infiniti calls it, it would not include the LH/RH Speaker Covers, LH/RH Child Seat Anchor Covers and miscellaneous plastic push pins. However, if you can safely transfer these items from the old deck lid without damaging them, you can save a couple of $. Interestingly enough, the rear deck lid kit with brake lamp costs the same as the one without it.
im just going off of what the dealer told me, but ill update once i get home
IF ONLY I COULD LEAVE WORK RIGHT NOW!!!!
No Soliciting
If you're interested in ordering the flat rear deck lid from my dealer, PM me and I'll provide you with the info. BTW, I'm South Florida.
you will have to drill
there are 3 bolts in the middle that hold it on, and a clip near each end, and double sided tape on the front edge and on the ends of the back corners
or you can skip using the 2 clips and not drill
and actually.. i'll be looking at my car tomorrow with the spoiler off. if i remember, i'll take a picture
for you guys, does the rear spoiler come with the wire harness for the new 3rd brake light? i know there are 2 harnesses under the trunk lid carpet.. one for the camera and one for the brake light, and one grounding point right near where the harnesses connect
