Leak from passenger side window
Old May 18, 2008 | 12:30 PM
LSUg37's Avatar
LSUg37
Hey everyone. I noticed the other day when it was raining that the tweeter and mid range speaker grills had some water in them. I had not opened that door or rooled down the window so I know it was not due to the slight window rool from opening the door. I then noticed a bead of water run in from right above the tweeter and run down. I'm sure they will fix it when I bring it in but this should not happen with a $40k+ car.
I am also gonna see if they will replace my driver side leater cover. It is wearing so bad and I only have 3600 miles.
Old May 18, 2008 | 12:31 PM
IP37's Avatar
IP37
yea a few people have had that problem with water getting in there. mine does it a little too
DiamondGCoupe's Avatar
DiamondGCoupe
Most likely the window was not up all the way whether or not you think it was or not.
Old May 18, 2008 | 08:26 PM
Callaway's Avatar
Callaway
Arm flailing tube man
i had a similar problem with the g35. the dealer will adjust the window so it seals better.
Old May 19, 2008 | 01:09 AM
majin ssj eric's Avatar
majin ssj eric
I've had a bead or two of water come down from that area after a high pressure wash before so I know its possible...
Old May 20, 2008 | 02:14 AM
jay.diem's Avatar
jay.diem
yep take it in.... they should be able to take care of that
Old May 20, 2008 | 10:28 PM
g37sTX's Avatar
g37sTX
mine has had the same problem, both tweeters were soaked last heavy rain we got here
Old May 20, 2008 | 10:33 PM
TerribleONE453's Avatar
TerribleONE453
just get the window realigned..
Old May 20, 2008 | 10:37 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
I had that issue in my G35 C. The dealer replaced my weather stripping and I never had the issue again. I also made sure that I kept the weather strip conditioned with lexol so that it's protective coating didn't wear away from washing etc...
Victory
17
Oct 27, 2022 03:45 PM
cellwoot
Sep 7, 2018 07:10 PM
pcwd
Sep 15, 2015 10:06 PM
Falker11
Sep 9, 2015 08:53 PM
rgs3
Intake and Exhaust
Sep 9, 2015 03:10 PM
