Replacing Reverse lights with LEDs
Old Apr 22, 2008 | 08:10 PM
thexfactor's Avatar
thexfactor
HERE, the poster says to replace the reverse lights with:
194 168 W5W 2825 SMT Tower III from autolumination.com
Im making an order from superbrightleds.com for all my other replacements (map, door, license, trunk) and I want to make one big order so i want to know if i can replace the reverse lights with these:
http://www.superbrightleds.com/mini-wedge.html#921/912
The stock reverse lights are "921" bulbs, and on the link above, at the bottom, it says "Replaces: 194, 921, 922..."
Anyone know one way for sure?
Old Apr 22, 2008 | 11:35 PM
wrathletik1's Avatar
wrathletik1
The 921x12 is the exact one I used. It fits but it is kind of loose, so I had to secure them with some medical tape. I'm thinking the 921x9 would fit better and more securely. If you use the 921x9, let us know if it is a snug fit.
Old Apr 23, 2008 | 03:36 AM
thexfactor's Avatar
thexfactor
The only differences between those two lights as far as I can see, is that according to superbrightleds.com (and I'm doing this from memory from my blackberry) is that the 921x9 is .05 inches longer (which I'm assuming is the reason your hoping it'll be tighter) and it is a "narrow viewing angle" bulb (as opposed to a "wide" viewing angle)
Foresee any problems there?
Old Apr 23, 2008 | 03:50 AM
TerribleONE453's Avatar
TerribleONE453
should work fine...
Old Apr 23, 2008 | 05:41 AM
thexfactor's Avatar
thexfactor
Originally Posted by TerribleONE453
should work fine...
Did you replace your reverse lights? If so, with what?
Old Apr 23, 2008 | 08:22 AM
DrJones's Avatar
DrJones
Anyone seen the reverse lights in the Cadillac CTS/DTS? They are very nice. I've been searching around looking for the bulbs and/or LED's that GM uses.
No luck yet.
Old Apr 23, 2008 | 09:39 AM
shumby's Avatar
shumby
Dont for get about the vanity mirror lights. Autpillumination for them too
Old Apr 23, 2008 | 10:55 AM
gan78mao's Avatar
gan78mao
No luck yet.
yea i was suprised when i saw them.
i thought it was some guy tat replaced his reverse bulb, but happened to be all the CTS and DTS i saw.
Old Apr 23, 2008 | 11:03 AM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
I have bulbs at home to change them out....but Im still nervous to try and pull the tail lights out and yank....
Old Apr 23, 2008 | 11:05 AM
wrathletik1
I ordered 2 super white vanity bulbs from autolumination and they do not match, I asked for an exchange and they told me to buy another one. Does that sound right to you?
Old Apr 23, 2008 | 11:10 AM
wrathletik1
Yes you have to yank, but be careful bro. I scratched my bumper on the first light I did.
Old Apr 23, 2008 | 11:32 AM
]\[ /-\ ]\/['s Avatar
don't yank...push the tailight out from the inside
Old Apr 23, 2008 | 12:36 PM
thexfactor's Avatar
thexfactor
No luck yet.
yea, its super hot, and its stock...
Old Apr 23, 2008 | 12:38 PM
thexfactor's Avatar
thexfactor
how long did the whole process take?
Old Apr 23, 2008 | 12:43 PM
wrathletik1
I'm thinking the WLED-WHP would also fit because I put the Wledx5 back there at first and those fit perfectly, but were not as bright as the 921x12. The WLED-WHP are super bright and nice, I have one in my trunk.
