Black Pearl Emblems?
Old Dec 29, 2007 | 11:52 AM
leeladisky's Avatar
leeladisky
Anyone know where I can pick up a kit for the G37?
Old Dec 29, 2007 | 01:21 PM
jenman's Avatar
jenman
I have heard that removing your orig emblems and having them painted is a much cheaper option. Some ppl over on ClubLexus have painted the emblems themselves.
Old Dec 29, 2007 | 01:47 PM
speedracer g37's Avatar
speedracer g37
there are vendor guys that work with dealerships and tint shops that electroplate chrome emblems to gold or black chrome. google for your area.
Old Dec 29, 2007 | 02:41 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
This would look hot... gotta find info on it... anyone have experience getting this done yet? or on an old ride?
Old Dec 29, 2007 | 03:38 PM
vinnys coupe's Avatar
vinnys coupe
i would love to throw blk emblems on an IP
Old Dec 29, 2007 | 05:06 PM
leeladisky's Avatar
leeladisky
Yeah, it was me...
I was the guy that originally posted that trick and color code to use... Unfortunately, while it looked darn good on the rear, rocks and road debris made the front emblem look like swiss cheese (e.g., horrible). If the cost isn't exhorbitant, I will plate all the emblems so they match, however, if the costs are ridiculous, I will just plate the front emblem to avoid chips.
The look is achieved best when using the Lexus paint color called: Flint Mica (it's a charcoal / greyish with a black tint). If you paint them yourselves, you MUST treat the plastic with a plastic prep (available in spray) and then use VERY light coats of paint. Each coat will look spotty or "grainy" upon application, but when enough coats are applied (1-2 hours between coats, longer when humid), it will look perfect! The very fine coat application process will avoid the color sand requirement that most automotive applications require. Additionally, don't forget to do the same thing for a clearcoat to protect it and give that metallic, glossy look. The same, very light coat application process applies, but don't shake the clear coat or you will get air bubbles....
Hope this helps!
Lee
Old Dec 29, 2007 | 05:16 PM
MaxToTheG37
Id just like to buy new ones... so much easier...
Old Dec 30, 2007 | 11:57 PM
Jason@Riverside's Avatar
Jason@Riverside
better to purchase new emblems then remove / re-double sided tape...
new emblems for the Cv36 arent much at all...
Old Feb 10, 2008 | 01:49 PM
fsasO6's Avatar
fsasO6
If you were to spray them up yourself, no matter how much you prep them and what not, they will still look like garbage after a couple weeks of driving. They will chip and start to crack. Your better off getting them plated.
Old Feb 10, 2008 | 02:09 PM
DiamondGCoupe's Avatar
DiamondGCoupe
You could get your Mt. Fuji emblem plated at any jewelery store but it would look pretty ****ty IMO.
Old Feb 10, 2008 | 02:32 PM
vinnys coupe
do u have blk emblems in for the g37s if so pm w price, n check ur emails =)
Old Feb 14, 2008 | 12:40 AM
SLaPiNFuNK's Avatar
SLaPiNFuNK
Jason doesnt work at Riverside INFINITI any longer...
Old Feb 14, 2008 | 12:56 AM
leeladisky's Avatar
leeladisky
I can get the emblems plated- it will be $350 for the set, not including the emblems, or $175 for both MT Fuji's without the emblems. If you are interested, PM me. It is expensive because it is sent out of the country as the process is apparently not permitted due to environmental concerns. I did just the MT Fujis and the new logos are not expensive. I do need new logos for ALL but the front Mt Fuji as the latter can be removed without damage as it is clipped onto the vehicle and is easy to remove.
L
Old Feb 14, 2008 | 03:18 PM
vinnys coupe
tony replaced him
Old Feb 14, 2008 | 03:19 PM
vinnys coupe
L
a bit confused how much would it be to paint all emblems on the back.. and how much is it just for the g37 sign..?? bc im not sure what im going to shave yet.. u can PM w price
