Notices
A Few Lighting Mods (Lotsa Pics)
Old 11-08-2007, 12:07 AM
UNV-IT46
UNV-IT46's Avatar
looks really good, I agree seems a little bright i probably will do the 5. but damn only lasting a couple months? might be better off just doing the piaa hyper whites throughout. they wont burn out...
Old 11-08-2007, 03:05 AM
aznutx
aznutx's Avatar
on that website what would be the model number to the "5 led" that was refered to because just judging form the picture , it does look quite bright, but ill be following ur suggestions to the t, for everything else. thanks
Old 11-08-2007, 08:08 AM
Motor25
Motor25's Avatar
Read post #12
Old 11-08-2007, 09:57 AM
RedHerring
RedHerring's Avatar
I don't think I have ever seen an LED burn out, except when explicitly trying to burn it out. I wondered about the heat generated by these arrays, and they are quite cool to the touch even after being on for a while. Long enough to have an incandescent bulb burn you. As long as the resister is holding down the current, they should run for quite a long time. We shall see.
That 12 element in the trunk without the bubble cover will probably fall out if you hit a big enough bump.
Old 11-08-2007, 07:58 PM
Keng
Keng's Avatar
From Wikipedia
LEDs have an extremely long life span. One manufacturer has calculated the ETTF (Estimated Time To Failure) for their LEDs to be between 100,000 and 1,000,000 hours.[19] Fluorescent tubes typically are rated at about 30,000 hours, and incandescent light bulbs at 1,000-2,000 hours.
LED performance largely depends on the ambient temperature of the operating environment. Driving an LED hard in high ambient temperatures may result in overheating of the LED package, eventually leading to device failure. Adequate heat-sinking is required to maintain long life. This is especially important when considering automotive, medical, and military applications where the device must operate over a large range of temperatures, and are required to have a low failure rate.
Old 11-10-2007, 02:14 PM
Comatose
Comatose's Avatar
Has anyone replaced the vanity mirror lights, and know what type of bulbs they take?
Old 11-10-2007, 06:41 PM
myk1013
myk1013's Avatar
Thanks for the post. Now put those license plates back up!
Old 11-12-2007, 09:22 PM
G37_Ryder
G37_Ryder's Avatar
Yeh. Wat size is the vanity light tube. Also, how do you switched out the hesdlight one. The same one
Old 11-13-2007, 02:04 AM
Motor25
Motor25's Avatar
I don't have license plates yet
Old 11-13-2007, 04:00 AM
Comatose
Comatose's Avatar
Yanked mine out today.. looks like its a mini festoon (29mm x 5mm). superbrightled's dont carry them in that size, but autolumination does.
Old 11-13-2007, 10:24 AM
RedHerring
RedHerring's Avatar
I replaced my license plate illumination with ( 2 X ) 7 element leds, and it helps immensely with the back up camera at night. Seriously.
Old 11-13-2007, 11:05 AM
Callaway
Arm flailing tube man
Callaway's Avatar
These LED's are just plug and play? Is it as easy as replacing stock bulbs?
Old 11-13-2007, 03:37 PM
RedHerring
RedHerring's Avatar
Yeppers, plug and play. Only problem is that you have to get the polarity correct before they will light. That comes from them being a diode. If you get them backwards it won't hurt them, they just won't work.
Old 11-14-2007, 11:04 PM
  #29
peterbanks
peterbanks's Avatar
The smallest festoon I saw on Autolumination was the "Vanity Mini 3 LED" and it was a 31mm x 5mm. Where did you see the 29mm x 5mm. Thanks.
Old 11-15-2007, 02:14 AM
  #30
Comatose
Comatose's Avatar
29x5mm was my personal measurement of the bulb i took out. My guess is the 31x5mm mini festoon should probably squeeze in and fit.. (but dont take my word for it!)
Quick Reply: A Few Lighting Mods (Lotsa Pics)
