Edge of door paint
Edge of door paint
I was opening the door and kind of hit the fence and left a scratch on the edge of the door. Does anyone know how to get rid of scratch on edge of the door? It seems like its kind of deep? I can see the the brownish color from the white paint
if its down to the metal through the paint your screwed. Your only option is to buy touch up and paint with that. If the scratch is not down to the metal you can wet sand and buff with compound then polish it out and you should be fine. But i would not recommend doing wet sanding if you have never done it before. You will screw up your paint if you dont know what you are doing....
ck1109
Oct 15, 2015 11:06 PM
FlyIce
Sep 29, 2015 04:07 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
