Electrical issue, possibly bad BCM
Old Apr 7, 2024 | 12:41 PM
Scottfreidel's Avatar
Scottfreidel
Hi everyone,
I was a victim of the leaking firewall grommet and the passenger front seat floor got flooded. This was about 10 months ago, but I think this issue I am having is a result of that.
Its a 2009 g37s. My battery drains often and frequently (need to jump it every other start). I think the issue is the bcm. When the car is completely powered off, I sometimes see the key icon flashing on the dash and hear a clicking (see videos below). The clicking appear to be coming from inside the bcm. Everything works on the car, except the battery draining. Does it sound like the entire bcm needs replaced, or is there some module or just part of it that could be related to the key icon flashing where I could just replace that? When I unplug the green connector seen in the below photo, the clicking stopped (maybe that's because I am killing power to it though)
below is a video of the clicking sound
https://youtu.be/KAfgIbtTD8M
and this is a video of the light on the dash blinking
https://youtu.be/mcmuFVG6E28?feature=shared
any suggestions where to get a bcm without dropping $800.
Thank you all very much for reading and any thoughts are appreciated.
Old Apr 7, 2024 | 01:26 PM
mcea's Avatar
mcea
would headphones help localize the noise https://etools.bg/userfiles/productl...duct_34823.jpg
Old Apr 7, 2024 | 01:37 PM
ILM-NC G37S's Avatar
ILM-NC G37S
1. Is the light on the cluster really flashing that fast?
2. Can you confirm 100% that the clicking is coming from the BCM? A long screwdriver placed on the side of the module with your ear to the handle will help to confirm.
3. Are there any codes?
If either #'s 1 or 2 are true, then more than likely the BCM will need to be replaced. Keep in mind that replacement WILL REQUIRE syncing (programming) to your car.
Old Apr 7, 2024 | 01:47 PM
Scottfreidel
16 bcm codes actually. Sounded more and more like the bcm needs replaced.
Old Apr 7, 2024 | 01:53 PM
ILM-NC G37S
As mentioned, if you can confirm the clicking is internal to the BCM then, yes, replacement is likely necessary.
Old Aug 19, 2024 | 02:40 PM
jpswain4's Avatar
jpswain4
9.3amp parasitic draw, every 15 seconds while powered off.
Scott, did you wind up replacing the BCM? Your description of the battery drain while everything else in the car working fine, aligns with my symptoms. I do not see a single dash light nor hear any clicking like you've captured (so far).... I have pinpointed the parasitic draw to be through the Fusible Link (bottom right 3 part position for 40/30/50amp FL) in the fuse box directly in front of the battery, labeled for the Power Windows, ABS ACTR, and VDC... It's literally shooting up over 9.3amps every 15 seconds or so, while parked, so after a couple days the battery is dead. I'd love to learn anything else you encountered or what you wound up doing to solve your scenario, if you don't mind sharing.
Thanks,
JPSwain4
TheBradIsMAd
Feb 19, 2024 02:47 PM
dexterd
Mar 31, 2020 12:56 PM
Walter.ace
General Tech Questions
May 23, 2017 10:56 AM
coastalsquirrel
Dec 13, 2014 08:09 PM
PR_G37
TSB - Technical Bulletins
Aug 23, 2011 04:22 PM
