Help 2009 coupe heated seats always on
Old Mar 5, 2024 | 07:28 PM
JoeDirrtyy's Avatar
JoeDirrtyy
So I just recently swapped to better conditioned seats (not sure what year the donor seats are from) they hooked up perfectly, same wiring.
I have the 2 dial switches with only the heated option and they still indicate with a light whether they are turned on or off.
The heated seat function always stays on now and not too sure if I need to get the switches instead of dials.
Another issue is that the driver seat bottom heats up, but not the back,
while the passenger seat back heats up, but not the bottom.
Old Mar 5, 2024 | 07:44 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by JoeDirrtyy
...(not sure what year the donor seats are from)...
This is a very important detail... you probably should have done more homework. If the donor seats are from a 2008 (ie. the rocker switch for the heater) then they are not compatible with your 2009 that has the dial switches.
Just because they "hooked up perfectly" does not automatically assume 100% "plug-and-play." Obviously there is a wiring issue as the seat heaters are not working as intended.
Find out the year of the donor car, if possible, then go from there.
Old Mar 6, 2024 | 11:20 AM
JoeDirrtyy's Avatar
JoeDirrtyy
I was able to pick them up from the marketplace for a good deal in good condition,
the seller is unsure of what year the seats came from, so I’ll probably have to find a part number on them.
For my understanding, the wiring should be the same for installation up to 2013,
but if you have any other insight, that would be helpful.
I am under the impression that I should just have to swap out the dial switches for the correct year to match the seats.
There were a couple forums I read up on this, but still looking for a more straightforward answer
Old Mar 6, 2024 | 07:13 PM
13_SkylineSedan's Avatar
13_SkylineSedan
Here's the FSM for your '09 coupe seats:
https://www.nicoclub.com/service-man...F2009%2FSE.pdf
If you happened to have gotten '08 seats then you can see the difference here:
https://www.nicoclub.com/service-man...F2008%2FSE.pdf
Basically in '08 and earlier the heaters were simply controlled by relays but in '09 they added the dial control and a "Control Unit" with temp sensors.
Old Mar 11, 2024 | 10:09 AM
deakdi's Avatar
deakdi
I do not forget seeing a thread like this awhiiiiiiiillle in the past, but my seek has yielded handiest the ones complaining they don't get warm...With over one hundred degree temps and file humidity degrees in New Orleans right now i dread getting inside the automobile for my 1 hour trip each manner...Motive force's facet heated seat is caught ON...Does every person recognise if there's a fuse i'm able to yank to reduce them off with out effecting anything else, i may not have a hazard to get to the dealership until next week.
192.168.100.1 192.168.1.1
Old Mar 11, 2024 | 11:32 AM
13_SkylineSedan
deakdi, what year and model car are you driving so we can look up what fuse to pull?
It's_me
12
Dec 17, 2012 08:34 AM
NeverBoneStock
Oct 25, 2012 03:07 PM
Davidk2002
13
Jul 26, 2012 03:21 PM
SpeedBump
Dec 5, 2011 03:29 PM
dnieto82
14
Aug 8, 2011 01:22 AM
