Help Electrical Issues when heated seats are on
Old Apr 6, 2022 | 05:25 PM
Skullcrusher's Avatar
Skullcrusher
Exclamation Electrical Issues when heated seats are on
Hello everyone,
I recently purchased a 2011 g37xs and have come across a very interesting issue. The car has an aftermarket subwoofer and obviously an amp as well. I was driving around with both heated seats on at night with the radio on as a well when all of a sudden all of the lights came on in the dash, the car unlocked itself, tachometer and the speedometer reset (almost as if the car remote started while driving) and the car sort of jolted. It did it a couple times repeatedly until I turned off the heated seats and then restarted the car. I also have a check engine light on after the problem. I took the car to the dealership and they are stumped as to what the issue is and they believe it has something to do with the aftermarket speakers. I checked the battery and while it was running to make sure it had nothing to do with the alternator and battery. Any ideas would be greatly appreciated.
Thank you
Old Apr 6, 2022 | 06:26 PM
SonicVQ's Avatar
SonicVQ
Unfortunately when a shop modifies the car's wiring, it is almost impossible to help over the internet.
If I were you, I would remove the sub/amp and see if the problem happens again.
If if does, you will need to take it to a good shop to figure out what the stereo installed did.
Old Apr 6, 2022 | 06:33 PM
Skullcrusher
If the wiring is directly from the battery to the amp it could still effect the ecu?
Old Apr 6, 2022 | 07:43 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by Skullcrusher
... I also have a check engine light on after the problem.
1) What were the codes?
2) Are you able to repeat the problem? ie. If you turn the seat heaters ON does the problem return?
3) How healthy is the battery?
These cars get VERY finicky when voltage drops- for whatever reason.
If I were to guess, perhaps you were drawing too much current (both seat heaters, lights (at night), radio (+ goodies), likely HVAC (blower)) and it was just a fluke. The alternator should be able to handle the load/ demand, but...
I've run both seat heaters, the steering wheel heater, radio, lights, etc. with no issues. However, I do not have any aftermarket amps nor do I have anything connected directly to the battery.
Like SonicVQ suggested, if the problem persists, disconnect the aftermarket gizmos- especially if they are directly connected to the battery- and see what happens. I'd also make sure the current sensor (attached to negative battery cable) has not been bypassed.
Old Apr 7, 2022 | 08:33 AM
SonicVQ's Avatar
SonicVQ
Yes... and to verify that disconnect the amp.
Old Apr 10, 2022 | 05:30 PM
Skullcrusher
Hello everyone,
I would like to say thank you for your help. So i believe I fixed it. I went to get a new battery for the car and when changing it I saw some of the most terrible wiring I have every seen. I am 90% positive the issue was caused by this because I found what looked like some sort of remote start setup and removed it as well and put the new battery in. After that the check engine light went away. And I still have the amp and the subs in the car with 0 issues. I will keep everyone updated if an issue occurs
Thank you.
Old Apr 10, 2022 | 08:33 PM
13_SkylineSedan's Avatar
13_SkylineSedan
Well done!
Glad you got it sorted out.
And thanks for letting us know.
Max2011
Feb 8, 2020 08:55 AM
gman69
Jul 21, 2016 12:42 PM
G37Salvador
Oct 22, 2009 03:17 AM
SOLISIMO
Jan 8, 2009 10:23 PM
hankuknamza
Sep 25, 2007 05:57 PM
