Radio On - No sound at all? Help Please
Old May 31, 2021 | 12:48 PM
govtdog's Avatar
govtdog
I have a 2012 Infiniti G37s hardtop convertible and the audio system appears to work but produces no sound at all. Initially, it would crackle while playing music but now nothing. It also would intermittently work but now no sound for more than a week.
Is it most likely the Bose amp? If so, where is the Bose amp located? Is it in the left side of the trunk area like other G37s or somewhere else?
Or, is it a loose connection and if so, where should I look to find it?
Thanks for any and all help you can offer.
John
Old May 31, 2021 | 05:46 PM
kiseliok's Avatar
kiseliok
G37 Community Team
Is the result any different with the roof up or down?
If not, you might have better luck posting this in the general audio section as the audio is mostly the same between these cars (minus the roof up/down switch).
Old Jun 1, 2021 | 10:11 AM
govtdog's Avatar
govtdog
No sound roof up or down.
Thanks!
Old Jun 1, 2021 | 02:52 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Oddly enough, you're not the first 'vert owner who has had Bose amp failures... Depending on your skill set, the most you could do is check for power/ ground at the amplifier. I would also check all of the wiring harnesses in the trunk area- with all those moving parts for the roof operation, it wouldn't take much for a wire to get pinched/ frayed/ damaged.
But first, simple item first: did you check the fuses for the Bose amp? (I think there are two separate fuses).
Now, if you haven't already, I would suggest you download the AV (Audio/Visual) section of the factory service manual for your car from here. From there you can read up on how to perform the self-diagnostic functions to check the Bose amp connection and also run the speaker test. The diagnostic will also list any AV-specific error codes that are detected, if any.
JUST PRESS THE BACK BUTTON TO EXIT THE SELF-DIAGNOSTIC. DO NOT SELECT THE RESET/INITILIZATION OPTION!
The above will get you started.
LORDHAVEMURPHY
Apr 24, 2021 11:09 PM
jimt29
Jun 6, 2020 03:44 PM
wagge
Mar 2, 2013 10:41 PM
RX Law
Motorsports / Track
26
Jan 7, 2012 05:25 PM
r6rider211
Car Care & Detailing
Sep 22, 2011 10:40 AM
