Dead Battery
Old May 1, 2021 | 05:58 AM
baylorex97's Avatar
baylorex97
Dead Battery
Well, once again I need help from you guys. Quarantined for a couple of months. Of course, battery hard died. Not even a click from the push button. Multiple battery chargers would not even recognize it. dead, dead, dead. After a few days and a new charger, it started. Backed it outside and let it run for 20 minutes. Pulled it inside, cut ignition, tried to start. Nothing. dead. Does the engine need to be engaged for alternator to charge? All components tested good before we got locked down.
Old May 1, 2021 | 12:22 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Get yourself a battery tender. Leave attached when car not in use for extended periods. This will maintain the battery without over charging. These may or may not work to revive a dead battery.
Letting the car idle for 20 minutes just wastes gas. I believe these cars use a smart alternator which puts out based on load. Solution above is best.
Old May 1, 2021 | 12:34 PM
ILM-NC G37S's Avatar
ILM-NC G37S
+1 for what Jsolo advises. A idling engine will never fully charge a "dead" battery. If your battery has been dead "for months" then likely it is shot and needs to be replaced.
I bought three of these from
Amazon Amazon
for my 2 vehicles and 1 for my tractor. Simple to install and the battery is always charged and ready to go. When I need to go somewhere, I simply unplug the tender, disconnect the cable, and go. Takes less than 30 seconds and I don't even have to open the hood.
Best $25 you will ever spend.
Old May 2, 2021 | 01:02 PM
RA081224's Avatar
RA081224
+1 for Jsolo's advice. When a car's electrical system only supported a coil and spark plugs that drew no current when the car wasn't running are long gone.
clouser
Jul 4, 2022 01:48 PM
aaipeng
General Tech Questions
Jul 27, 2020 01:48 PM
jayfickle99
Sep 16, 2013 07:47 PM
Amon_Ra
Nov 9, 2011 02:54 PM
sculhane
Dec 12, 2009 12:56 PM
