How I displayed Android Auto on the stock screen for less than $50
Old Apr 24, 2020 | 11:52 PM
  #31
icecube45's Avatar
icecube45
Originally Posted by iCrap
That would be cool, looking forward to checking that out.
I just looked up intelligent auto and I can't find anything... got a link? Also, I ended up getting the paid version of OpenAuto Pro and have been messing around with that, it does seem way more responsive than Crankshaft, boot up times are better as well, and it supports Pi 4.
https://github.com/rsjudka/intelligent-auto
Running mine on a pi4
Old Apr 24, 2020 | 11:57 PM
  #32
iCrap's Avatar
iCrap
OH, I did see someone posted that on Reddit. I'm gonna give that a try. I see it has OBD support which is cool, openauto still dosen't have that.
Old Apr 25, 2020 | 12:12 AM
  #33
icecube45's Avatar
icecube45
That's the bit I've mostly been working on - we're structuring a rewrite of the whole OBD implementation right now. I'm waiting for my new PCBs to get here so I can start CAN sniffing the G37 and integrating more things into android auto (such as setting day/night mode off of the headlight status).
Old Apr 25, 2020 | 12:19 AM
  #34
iCrap's Avatar
iCrap
That would be very cool. I was planning on trying to figure out a way to do some of that as well. If possible, I'd like it to integrate the climate control temperature into it as well. That's the only reason I ever switch back to the stock interface now.
Old Apr 25, 2020 | 12:36 AM
  #35
icecube45's Avatar
icecube45
That's one of my goals! From everything I've read on the technical service manual, it shouldn't be an issue. Just waiting to be able to confirm so.
Old Apr 25, 2020 | 12:47 AM
  #36
iCrap's Avatar
iCrap
Hopefully we can get something working on our cars, you should post a thread with your findings as well. What hardware did you order for CAN sniffing? I have seen stuff like the PICan2 available.
Old Apr 25, 2020 | 12:49 AM
  #37
icecube45's Avatar
icecube45
My goal is to make a thread with a list of documented CAN frames.
I'm getting a custom made variation of a CANable.
Old Apr 25, 2020 | 12:01 PM
  #38
rotarymike's Avatar
rotarymike
Moderator in Moderation
This thread just got way more complicated/interesting. insert <popcorn.gif> but in a good way.
Old May 8, 2020 | 10:54 AM
  #39
Bman427's Avatar
Bman427
Interested in the plug and play version.... '13 w/ Bose and NAV... PM if/when it is available...thanks
Old May 8, 2020 | 01:30 PM
  #40
Conboss's Avatar
Conboss
Now we’re talking. Everything I want to do seems to be on your lists as well! Just a thought, I wonder if you could sniff OBD using a wifi/Bluetooth obd dongle
Old May 12, 2020 | 04:11 AM
  #41
hiddensalami's Avatar
hiddensalami
Is there going to be a plug and play model of this? 2008 Nav Bose system
Old May 12, 2020 | 11:23 AM
  #42
iCrap's Avatar
iCrap
No, but maybe a kit. Whenever I get time to work on that.
Old May 13, 2020 | 10:42 AM
  #43
rotarymike's Avatar
rotarymike
Maybe you should do a kickstarter so the people demanding p-n-p kits can pony up development costs...
Old May 13, 2020 | 11:39 AM
  #44
Lee Nguyen's Avatar
Lee Nguyen
So, I was able to get android auto working on my car with the help of a Raspberry Pi and a few mods to the stock screen assembly. This uses a Pi 3 running the free Crankshaft NG software.
Parts needed:
- Raspberry Pi 3 + SD Card. (8GB or higher)
- 7" USB Capacitive touch screen digitizer (https://www.ebay.com/itm/7-inch-capa...72.m2749.l2649)
- Composite to HDMI converter (for pre 2010 cars) (https://www.ebay.com/itm/RCA-to-HDMI...4AAOSw3bNdVG~Z)
- High power USB hub to power everything
Setting up the Pi:
First thing you want to do is configure your Pi. Download the software and follow the instructions on their website:
https://getcrankshaft.com/
Note that after you flash the image, you need to change the config so the display will show up properly on a 7" display. Put the following at the bottom of config.txt on the root of the SD card.
After, plug in your USB cable and make sure android auto is working before installing in the car.
Modifying the display:
The car already has touch screen overlay for it's factory nav system. Its useless and will need to be removed. Basically we need to open up the housing, separate the screen from the digitizer, cut a slot for the new ribbon cable, and reassemble.
Display after removing the stock digitizer, sticking the new one in it's place
You need to cut the housing like so, to allow the cable to pass through.
The controller for the digitizer will be mounted under the screen, like this.
Getting video onto the display:
This will vary depending on your car's year. My car is a pre-2010 with RCA inputs in the center console. I simply used an RCA to HDMI converter to get the pi's display onto the screen. The quality isn't the greatest, so I will revisit this in the future.
If you don't have the RCA or your car is post 2010, you may need a converter such as the naviks unit: https://naviks.com/i-22763577-2007-2...tegory:1137501
After this, the rest is simple. Just reassemble the car and verify everything is working. If you do it this way the volume and climate controls will still show up when you turn the *****, backup camera and stuff obviously works fine as well.
I ran all the power to my center console, and then ran wires to hide the Pi under the passenger seat. This way i can still easily reach it if i need to change the firmware or something.
Future improvements:
As you can see from the pictures, with the HDMI to RCA converter the quality isn't the best. Also, my 2007 G does something weird with the signal, and the center of the picture is slightly squished. Even stranger, when you adjust the volume the picture un-squishes and then goes back to being distorted once the popup goes away.
For a future improvement I'll either buy the Naviks unit to bypass the OEM system completely, or i will simply replace the entire center screen with a new one.
Sir, where are you? I need your location because I'm willing to pay you to do it on my car since I absolute know nothing about car electronic stuff. Joke aside, it's nice though. I'm so sick of not having songs played via Bluetooth on my car. I keep forgetting to bring the USB inside to load more new musics into just so I can play songs via the USB port.
Old Jun 4, 2020 | 07:05 PM
  #45
Conboss's Avatar
Conboss
Well, after acquiring a pi4, micro HDMI to HDMI, hdmi to composite and a little more wiring, she displays! Installed lineageOS on it which made my laptop crash, but it works! Next steps are streamlining it and making a package for all the pieces to sit in.
