playing audio through samsung
Old Jan 26, 2020 | 05:57 PM
lostinspace's Avatar
lostinspace
I have a 2013 with no navigation. My samsung is connected to make calls through bluetooth but it won't play music. Wondering if there is a way to either (1) play music through the USB connection or (2) play music through bluetooth. When I push the "aux" button on the dash display I only see 6 sirius xm stations listed so I'm not sure how connecting through the aux would work.
Old Jan 27, 2020 | 03:51 PM
13_SkylineSedan's Avatar
13_SkylineSedan
No BlueTooth audio streaming without nav (that was mean of them) but you should be able to play audio through the USB jack under the arm rest. Plug your phone in there, start it playing music, then try cycling through the "source" button on the steering wheel. It may say "iPod" because that's how old and out of date our InfoTainment systems are, but that should work.
Old Jan 28, 2020 | 08:21 AM
Surfnazi's Avatar
Surfnazi
You have to set phone to connect both phone and music under settings connections
Old Jan 28, 2020 | 09:57 PM
Epiphany's Avatar
Epiphany
OP, neither of these will work. Without nav your android phone has no way of playing music on a stock car. What I and a few other members have can be found here: https://www.myg37.com/forums/audio-v...ipped-car.html Once in a while I can't connect without restarting the car, but it was 100% worth what I paid for it. There are other options if you do some looking but it worked for me. Don't waste your time or money with the $20 options that say they'll work.
Old Feb 2, 2020 | 10:16 AM
lostinspace
Thanks. I've tried both kinds of USB to Type C connections (2.0 and 3.1) and neither work. Do you think a USB to audio jack connection might work?
Old Feb 3, 2020 | 08:36 AM
Surfnazi's Avatar
Surfnazi
have you tried removing and readding the phone to connect as both phone and music source? Latest android at least the android 10 let's your phone have dual audio output to 2 sources so you need to make sure your phone is set to connect to your car as both sources
Old Feb 3, 2020 | 09:37 PM
lostinspace
Under my bluetooth advanced settings there is a "dual audio" setting but because I don't have navigation the bluetooth connection isn't possible. I've messed around with other settings and tried the USB connection again but no dice. I'm stuck except to try a USB to audio jack device.
Old Feb 6, 2020 | 06:12 AM
Surfnazi's Avatar
Surfnazi
You could get a usb bluetooth adapter and connect through that. This is why I kept my old iPhone's to use as ipod
Old Feb 8, 2020 | 09:42 AM
Blackmatic's Avatar
Blackmatic
I just bought a 2013 G37 non-navigation which I'm faced with the same dilemma. Many satellite radio replacement devices such as the Grom Audio and others like USA SPEC BT45INFI, and SAT CAT exist to do the job. The issue for me is I have the XM subscription and I'm not willing to give that up for something aftermarket.
The only device I found that gives hope is this one: https://www.viseeousa.com/products/v...ant=3977406596
If we can find a replacement were in business.
Old Feb 8, 2020 | 10:10 AM
Blackmatic's Avatar
Blackmatic
I feel stupid to just realize the WMA1000 may work just as well. You'd just need a USB to iPod 30-pin cable which are found anywhere.
I'm going to try shooting the manufacturer an email. If I can't get a response I may just buy it off Amazon and return it if it doesn't work.
Old Feb 8, 2020 | 11:21 PM
Epiphany's Avatar
Epiphany
For what it's worth on my car with the USA Spec unit it alternates whether it goes into SAT or into USA Spec each time I press the AUX button.
Old Feb 12, 2020 | 08:45 PM
Blackmatic's Avatar
Blackmatic
I just got the WMA1000 and can confirm it does NOT work with my car.
One Amazon user has an older G that had the non-usb connection with the older proprietary input and has it working. I thought I'd give it a shot. Oh well, I'll return these items and get my refund and figure something else out.
Old Feb 12, 2020 | 10:31 PM
Blackmatic's Avatar
Blackmatic
Thanks for the info.
I'd like to look more into the NAXA device if possible.
I just looked in my arm rest and realized that I had one there all along. It stutters and lags, but it works. Just suggested an improvement I might try. into https://www.myg37.com/forums/audio-v...ml#post4266362
dhawal.chheda
Jan 29, 2016 10:00 AM
raju687
Nov 8, 2013 11:36 AM
Tek Jansen
Oct 19, 2013 10:31 PM
Joe'sG37x
Mar 19, 2013 04:09 PM
S4_STI_G37
Sep 7, 2012 07:04 PM
