Car Window Issues
Old Oct 9, 2019 | 07:32 AM
ziggsta's Avatar
ziggsta
Angry Car Window Issues
To start I have already poured through these forums and still cannot find a solution. Looking for assistance, please.
To start the rear passenger window would not go back up, the lock buttons stopped working as well as the memory setting buttons. I replaced the window master switch and all was well for a while. However now when I roll down my driver's side window the rear passenger window will go down on its own and will not go back up. I have no idea what is going on. It is a 2009 G37X. Once the car sits off for a while eventually the window will go back up. Any ideas??? I did purchase the window master switch from a junkyard maybe I just got a bad one??? Yesterday morning the radio lcd also went really dim.
Old Oct 9, 2019 | 06:35 PM
Kemp0937x's Avatar
Kemp0937x
So I had the same issue! I got the tiniest bit of water in my door panel. Next day only my driver window worked but the auto didn’t work. So all three other windows don’t work, lock and auto lock button doesn’t work or my window adjust. I pulled it all apart to the circuit board, dried everything out. Still doesn’t work. Find any fixes?
Old Oct 9, 2019 | 06:44 PM
ziggsta's Avatar
ziggsta
I am so annoyed right now! I got the rear door panel off, but I cannot figure out how to access the window motor! In other threads, there is a silver panel but the rear G37x door does not have this! How do I get access to the motor???
Old Oct 9, 2019 | 06:55 PM
Kemp0937x's Avatar
Kemp0937x
Man I have no idea! I only took driver window button panel off. I absolutely hate panels too 🙄
Old Oct 10, 2019 | 06:25 PM
Conboss's Avatar
Conboss
I had my driver door panel off a while back, the freaking window motor and track are within the entire door!! PITA. Anyone know how to get to the track? My window has been going down very notchy, and i want to lube the track to try and make it smooth once again.
Old Oct 10, 2019 | 07:32 PM
CubanDre's Avatar
CubanDre
I had something similar. This should do the trick:
Old Jan 10, 2020 | 10:26 AM
zpzp's Avatar
zpzp
https://www.youtube.com/watch?v=9rX9UJ-X_7U
this happens about once every 6 months for me as well and the only successful diagnosis has been this reset! I feel your pain
Old Jan 11, 2020 | 05:21 AM
Surfnazi's Avatar
Surfnazi
Make sure nothing is stuck in window track or that the regulator isnt damaged
Old Jan 11, 2020 | 11:14 AM
Kemp0937x's Avatar
Kemp0937x
i still have the same, unresolved issue as before. I thought maybe after some time it’d dry out on its own but it hasn’t. I thought it may have been a fuse but the only one I located was still good. Know of any others? Also I’d have thought that if it was a fuse, nothing would work. But my driver window still goes up and down smoothly, but the auto down and up won’t work as well as all the other windows and my lock/unlock button. I have no idea what to do besides buy a new one 🤷🏽‍♂️
Old Jan 11, 2020 | 12:19 PM
Surfnazi's Avatar
Surfnazi
Have you done window reset yet
Old Jan 11, 2020 | 12:53 PM
Kemp0937x's Avatar
Kemp0937x
No, was that what the video was about?
Old Jan 11, 2020 | 12:57 PM
Kemp0937x's Avatar
Kemp0937x
See my passenger windows don’t work at all. Not just the auto. Only my driver works and that one won’t do auto. So I’m not sure wth the issue is. It’s an 09 sedan if that helps. I’m stumped and don’t want to pay out the *** for a new switch
Kboyd
May 9, 2018 02:51 PM
lester_vq37
Jan 3, 2018 08:22 PM
timmy0257
Jun 8, 2015 01:58 PM
CrazyBulgarian
Feb 20, 2013 01:53 AM
Blitzy
General Tech Questions
May 30, 2011 03:18 PM
