Code P0463
Code P0463
Alright guys. So today i just checked the car for any codes with the UPRev software. I do this periodically as a just because. The CEL light wasnt on in the car, but when i checked for any DTCs the code P0463 came up. So i did a quick search online and on here and found it to deal woth the fuel level sensor and ecm. I cleared the code for now to see if it comes back tomorrow. The wierd thing is. This morning i put my weekly gas in, and the pump was very difficult to get to stay pumping. One of those gotta hold it a certain way type of pump this morning. So for it to keep pumping because i know i was almost empty. I had to hold the pump to the side. Not wanting to do this. But was 4am and going to work. So you guys think this might have played a roll in this code? Or am i expecting bigger issues? Anyone have this happen to them and what did they have to replace. The fuel gauge is working. I filled the tank and drove to work and home and the typical ampunt seems to be reading on guage. Is this sensor eSy to replace? And if replacing the sensor do i do the pump as well since im in there? Thanks guys
Filling up the car could be the issue but then again I have that similar issue where at one gas station it would do that but in others it won’t. Maybe try another gas station see if it does the same thing if yes then that might be the issue.
Last edited by Baadnewsburr; 05-29-2019 at 10:22 AM. Reason: corrected info on fuel pump
Thank you guys for your ideas. I took rear seat out last night and checked the connectors just for ****s and grins. All looked good. I unplugged them. Cleaned them off with electrical cleaner because i was there. But still getting code. Its a soft code too. The CEL light isnt on which is wierd. Every thing i find online says that they get the CEL light. And talked with infiniti last night to make apt. And they said thats an unusual code. They normaly see P0462 which is a LOW input code mines a high input code. Just wierd that had issues with getting gas and now code. Guess i will wait to see what happens
here's a couple of videos on cleaning the resistors:
No. Just the connectors on outside of tank. Figured i would start small and work my way in if that didnt seem to work. It was late at night. Figured i would make sure the connectors were at least looking good. I now am not getting a code. I went out at lunch checked for codes 3 times. Drove the car around, nothinh. Will see again when i get home
Baadnewsburr (05-29-2019)
iVector
11-22-2020 11:20 PM
LuvMyG37x
General Tech Questions
11-15-2020 05:12 PM
iVector
11-11-2020 11:07 AM
mysticxknight
10-08-2011 06:36 PM
