Illumanated door rocker panel Infiniti logo half lit issue
Hey all!
So I searched and searched trying to find the exact name Infiniti gives to the illuminated Infiniti logo you see when you open the door (the rocker pane as you look straight down?) and found nothing really. So I turn to you all for help.
The issue is that only half of it is lit up now leading me to think that there is a bulb out (assuming it uses 2 here) and I cannot find a way to remove the cover to gain access to the bulb to swap out. I Googled it but could not really find anything useful as again I dont know exactly what its called.
Anyone run into this issue and was able to resolve it?
Thanks for any help!
It's called a puddle lamp or step lamp, about 3/4 of the way down the page.
https://www.discountinfinitiparts.co...al--front-door
If you can locate the FSM, it might under body/front door or electrical/front door
You might be talking about the illuminated door sills or kick plates. Please read this thread as it shows how to change the color or lights and may be helpful in troubleshooting your issue. https://www.myg37.com/forums/showthr...errerid=369648
