Bovee1000? Needs CableJive dockstubz?
Old Apr 6, 2018 | 10:20 AM
redwillow's Avatar
redwillow
20 Year Member
Still trying to get Spotify from the iPhone through the ipod adapter in a 2009 g37 with Nav.
Searching on here came up with the Bovee1000:
Amazon Amazon
which does seem to work, but only intermittently.
So from forum searching I'm seeing that it might also need a power adapter to work right, but the CableJive dockstubz:
Amazon Amazon
is discontinued?
So is there another option for the power adapter?
Or should I be using something besides the Bovee1000 ?
Old Jun 9, 2018 | 12:13 PM
lazyme's Avatar
lazyme
I got the Bovee1000 but it does not work on my G37 without a power adapter. Wondering if
Amazon Amazon
would be an alternative to the CableJive.
I'm going to order and try it out. Will let you know how it goes.
Old Jun 9, 2018 | 08:39 PM
mven74's Avatar
mven74
I tried the Bovee on my g37 using the cable jive, it did not work for me. I was able to link it but when I tried to stream anything, no audio. Couldn't figure it out so I returned both of them.
Old Jun 10, 2018 | 12:21 PM
jpowersjr2's Avatar
jpowersjr2
My Bovee1000 works pretty good. The only complaint I have is that sometimes it doesn't connect right away when the car is turned on but always connects within a few minutes of driving. I have an '08 coupe with Navigation.
Old Jun 11, 2018 | 08:51 PM
lazyme's Avatar
lazyme
The Bovee1000 doesn't power up for me. Does anyone know of any alternative to the CableJive to power it up? I have the 2009 Sedan without nav.
Old Jun 13, 2018 | 09:13 PM
mitcherapp's Avatar
mitcherapp
Any luck? I'm in the same boat. Bovee won't power up. Can't get the cable jive anytime soon. Only option on amazon is $38 and comes from Germany and estimated delivery is between July 5-25.
Old Jun 13, 2018 | 09:40 PM
mven74's Avatar
mven74
here is a solution for you...
Old Jun 13, 2018 | 09:49 PM
mven74's Avatar
mven74
don't bother. i couldn't get mine to work. waste of time and money.
Old Jun 14, 2018 | 01:56 AM
lazyme's Avatar
lazyme
Nope. That didn't work for me.
Old Jun 14, 2018 | 10:04 AM
mitcherapp's Avatar
mitcherapp
Too bad it doesn't work with a 2009 G37 with Nav. Same situation with the gromaudio bt-3. All I want to do is stream bluetooth with text display and steering wheel control. Ordered a different 30-pin 12v to 5v adapter off of amazon, but it won't get here until next week. I'll let you all know if it works.
Old Jun 14, 2018 | 11:07 AM
lazyme's Avatar
lazyme
Which adapter is that?
Old Jun 14, 2018 | 12:12 PM
mitcherapp's Avatar
mitcherapp
This one:
Amazon Amazon
It doesn't have the micro USB injection that the Cable Jive has, but hopefully this will power up my bovee.
Old Jun 15, 2018 | 05:38 PM
lazyme's Avatar
lazyme
This one: https://www.amazon.com/Xtenzi-Chargi.../dp/B0026AG38K
Great. Let me know how that works out for you.
I tried this solution and it works for my 2009 Infiniti G37 with no nav. Only problem is I cant use the steering wheel controls to switch songs as it changes the radio station instead. Also, I the bluetooth disconnects for me whenever I receive a phone call. Have you run into any of these issues?
Old Jun 18, 2018 | 02:10 AM
mven74's Avatar
mven74
no problem for me. I have my calls connect to the car Bluetooth. It would pause the music then resume after I end the call. I can't use the steering wheel to advance the songs, I use the **** on the radio to do that.
Old Jun 18, 2018 | 01:41 PM
mitcherapp's Avatar
mitcherapp
Just received it. It didn't power up the bovee. Not sure what to do at this point. Wait for a cable jive to come from germany or just return the bovee? I have an 09 G37 with nav, so not really any other options out there other to cough up $450 for the Grom VLine.
