Clock not working
Old Mar 14, 2018 | 05:40 PM
Jo3nahxS's Avatar
Jo3nahxS
Clock not working
So I have a 2011 g37 and my clock light spot working is there a quick fix
Old Mar 14, 2018 | 05:47 PM
Bostonreefer's Avatar
Bostonreefer
have not done it myself yet so can't speak from experience, but from what I read there is a loose connection that needs to be re soldered. pretty easy job from the sound of it once you get In there. I can speak from experience (wrapping my interier) its prettt easy to get there. Good luck let me know if you end up doing it. Share your experience as I will be tackling this project soon.
Old Mar 14, 2018 | 08:05 PM
Jo3nahxS's Avatar
Jo3nahxS
I think is a loose connection sometimes it blinks with the base
Old Mar 15, 2018 | 12:49 PM
Epiphany's Avatar
Epiphany
Swap a new clock or open that one up and resolder the LEDs. Takes about 10 minutes to get the clock out. It'll blink for a while then eventually not work anymore, super common issue on these cars. I swapped mine out for one out of a wrecked G not long ago.
Old Mar 15, 2018 | 09:54 PM
Jo3nahxS's Avatar
Jo3nahxS
Does the clock pops out or I need to remove the console
Old Mar 16, 2018 | 06:54 PM
Epiphany's Avatar
Epiphany
You need to remove part of the console. This video shows you how to remove it. Once you've got all the screws off the back of it and the front metal trim piece comes off the clock slides out, then just reverse the steps after. Shouldn't take you more than 10-15 minutes.
Andy Kim
Oct 2, 2017 07:18 AM
bobtaz13
Jun 20, 2017 04:54 PM
oquainb
Aug 9, 2014 05:12 AM
DevilsZ
Oct 5, 2009 12:37 AM
itsaGthing
TSB - Technical Bulletins
Nov 25, 2008 12:16 PM
