audio issues 2009 g37x
Old Feb 11, 2018 | 05:22 PM
kennek4's Avatar
kennek4
after checking fuse, and replacing power amp, I still have no audio, I learned about the hidden diagnostic page, when I checked error code history, it came up as "high frequency driver connection error". I don't want to assume(like I did with the power amp)that its as simple as a loose connection, any suggestions?
Old Feb 11, 2018 | 07:24 PM
Epiphany's Avatar
Epiphany
What have you checked so far? When did it start and was it working fine before? I'd be assuming it's loose connections and checking those before I went about replacing amps.
Old Feb 11, 2018 | 08:08 PM
kennek4's Avatar
kennek4
Thanks for responding! I just bought the car, and it wasn’t working when I got it. I bought it from a Kia dealership, and have a 3,000 mile warranty, but the stereo isn’t covered, so I’ve just been enjoying the sound of the car, lol!
I checked the audio fuse, then I made the assumption about the amp, fortunately I only spent $42, so now I have a spare! I then learned about the self diagnostic menu, and I went through all the menus, and everything checked out okay, the error code history showed the hf driver connection error. I also ran the speaker test algorithm and I don’t hear any tones, or anything?
I don’t know which side it’s on, and I don’t want to damage the door trim, are there any videos showing how to remove the door panels? Or is there a wiring harnesses under the dash with a connector I might be able to check first, etc?
I appreciate your time !
Old Feb 12, 2018 | 10:12 AM
telcoman's Avatar
telcoman
Follow the troubleshooting steps in the FSM
Factory Service Manuals - NICO Club
Telcoman
Old Feb 12, 2018 | 02:33 PM
kennek4's Avatar
kennek4
Telcoman
Thanks for the info, I’ll run through it after work!!
Old Feb 12, 2018 | 06:08 PM
ILM-NC G37S's Avatar
ILM-NC G37S
I did a quick check of the AV section of the FSM (2008 and 2014) but I could not find any reference to a "High Frequency Driver Connection Error." Check over the FSM (AV Section) for your car and get a better idea how to run the diagnostics protocols. Then, rerun the diagnostics and check for:
a) Component Connections- green, yellow or red?;
b) CAN Communication Status- TX/RX, OK/COUNT
c) AV Communication Status- TX/RX, OK/COUNT
d) Any NUMERIC Error Codes?
Most of the above will determine the state of the AV system and, specifically, the AV Master Controller (headunit). If there is absolutely no sound at all during the Speaker Test then likely the problem is either the headunit or the wiring to the Bose amp (or to the speakers if you do not have the Bose system).
It will be almost impossible to accurately diagnose your problem but will help in any way we can. Hopefully the above will give you a good start. By the way, what "amp" did you replace for $42?
Old Feb 12, 2018 | 07:58 PM
kennek4's Avatar
kennek4
I replaced the amp (exact same oem Bose amp) up behind the back seats, is there another amp? I saw someone refer to it as the sub amp, and that made me wonder!
Old Feb 12, 2018 | 08:31 PM
ILM-NC G37S
Bose (main) Amp (trunk)
Woofer Amp (trunk)
Unified Meter A/C Amp (mounted in dash on headunit)
Assuming you verified the Bose Amp is getting power than likely the amp is not receiving the sound signals from the headinit.
Old Feb 12, 2018 | 10:39 PM
kennek4's Avatar
kennek4
Man this forum is awesom! I really appreciate all of your responses! I will dig into all this info, and hopefully get it figured out in the next couple of days! I will keep you all posted! One side note, I did have the opportunity to appreciate the sound of a nice G35 I rolled up behind today on the interstate, which had a nice custom exhaust system!! One benifit of no audio!! Lol
looksezontv
Jun 5, 2019 05:13 PM
Lt8Che
Nov 13, 2016 12:54 PM
PetesSweets86
Oct 9, 2016 07:27 PM
crb1468crb
Oct 3, 2016 09:25 AM
Legz
Sep 19, 2016 08:28 AM
