Battery Size question
I am trying to find out what battery will fit in our stock location in the engine bay. From what I understand the G37 uses a series 35 which has dimensions of 9.1" L - 6.9" W - 8.9" H. I am thinking about getting a XS Power D3400 D3400 - XS Power and the dimensions are 10.28 L - 6.75 W - 7.24 H. Would getting this battery remove the necessity for adding another battery to my audio system (1000 WATT)? I would rather not add a battery to the trunk unless its needed.
I guess that +1" in Length is what kills it then? The other two dimensions are actually smaller than the 35 series spec. Crazy..
They do sell some batteries with reverse polarities. Just have to find the one you want.
I run a pretty decent sized audio set up daily
Nine.1 amp and a Soundstream TN4.900D. Roughly 2000-2200rms for the subs and door speakers
I run this battery
Battery - Duralast Platinum (35-AGM)
and the stock alt. Very little voltage drop.
I was impressed.
I run this battery
I was impressed.
Ok, the battery I currently have installed is a Napa 7524F, 24 BCI group, CA: 850 (675 CCA). L = 10.75" , H = 9.00", and W = 6.75. I want to install the XS Power D3400, 34 BCI group, CA: 1000 (CCA unknown), L = 10.25" , H = 7.2", and W = 6.75". In every size category the D3400 is either equal, or less than the NAPA battery. NAPA does not list my currently installed battery as even being a fit for the G37. Im trying to find a retailer close to me that I can have them dry fit the D3400in my car to verify that, according to the numbers above, it fits the G37.
I hope the D3400 will prevent me from having to install another battery to get clean, consistent power to my soon to be new system.
I want the D3400 too, that is a powerhouse of an AGM battery, 1000 cranking amps too. That's a **** ton. I had a XS Power battery in my last two cars, it's was awesome.
You won't need a second battery unless you're going 3000WRMS or above. Let me know if you get one to fit in the stock location without modification. I measured the stock tray and it will be super close to fitting length wise.
I am waiting on some cash before I order it. Im pretty sure it will fit based on my measurements. The fact that I have a battery in there right now that is larger than the car should be able to hold means someone may have done mods to the mount. Ill let you know once I get it.
2009 G37x can take a 24F battery, Group 34 or Group 35 battery
The 2009 G37X comes with a group 35 battery. The dimension of the group 35 battery are 10-1/4 (L) 6 7/8 (w) 8 7/8 (h)
If you read battery charts you will see that the 2008 G35 calls for a 24F battery. 10-3/4 (L) 6 13/16 (w) 10 3/4" ((h). The G35 and G37x are built on the same chasis.
The group 35 battery sits on a small battery tray (like a booster seat) to increase its height. Remove the battery tray and you will find a full side battery tray underneath. You can then install the 24F battery without a problem giving you much more CCA's
A group 34 battery is 10 1/4 (L) 6 13/16 (w) 7 7/8 (h). It will fit as well.
