Can not find speaker wire in footwell
Old Apr 16, 2015 | 08:36 PM
mmnjtwa's Avatar
mmnjtwa
I have a 2011 G37S coupe, and I'm trying to run new speaker wire from my amps to the footwell, where I plan to tap into the wires before the molex. I had no problem locating the wires on the driver's side, but cannot find them on the passenger side.
The wires for the woofer are supposed to be green and red, but I cannot find any with the proper gauge near the area. I've even tapped into light green and violet wires near that area, which are for the tweeter/mid but I'm not getting the proper ohm reading. I've checked in the trunk, at the plug, and get the proper reading there.
Any idea where to look in this area? It shouldn't be this difficult. I'm trying to avoid cutting in the molex to run through the door.
Thanks in advance.
Regards,
Jayson
This is a photo of the wires in the area.
Edit: can't seem to post pictures from my Flickr account.
Old Apr 16, 2015 | 11:33 PM
blazeplacid's Avatar
blazeplacid
If I remember right....the passenger side molex has an opening that you can easily pass wire through. I do know you must drill the drivers side.
Old Apr 17, 2015 | 02:08 AM
mmnjtwa's Avatar
mmnjtwa
Thanks. As of now, I have the right side tapped into the harness in the trunk. I may take a day to rerun the wires and go through the molex just for the right side. If things go smoothly enough, and I finish in a good mood, I may take some time to run the driver's side.
photocat
Sep 14, 2015 02:32 PM
allen738
Sep 6, 2015 09:36 PM
RexHavoc
Sep 6, 2015 01:03 AM
bingpwr
Sep 4, 2015 09:44 PM
