How to: replace your center channel speaker.
CriME, did you replace your stock speaker wiring when you replaced all of your speakers? I want to replace the wiring to something a bit cleaner/beefier. I went to my installer asking him if the speaker wire I bought (12 gauge) would work and he said he couldnt use it for the front speakers since he couldnt get it through or passed the connector at the door hinge. He suggested I just let him use whatever gauge wire he had that would work for my car. I really want to replace all my speaker wires to increase or ensure the signal quality to my replacement speakers/amps.
I bought new wiring to replace it, but in the end I didn't bother. I re used the existing wires and I had no issues at all. It made the install much easier. In the front doors, I'm running a pair of CDT HD-M6+ and in the rear doors I have CDT ES-06. These woofers are pretty beefy and the factory wiring supplies them just fine.
Do you consider yourself to be an audiophile? I used to be and am moving back in that direction once again. I wonder how many people on here have upgraded their factory wiring? I am sure I could use the factory stuff and would probably be ok with it, but I really fee like I should change it out. lol. Im too stuck on details and leaving old crap in bothers me. Might not have a choice if I decide to do the whole install myself.
If you re-used the factory wire, I imagine you had to splice/or solder into the harness feeding the speakers to connect them to your amp(s)?
Yes, I left the factory harnesses in place in case I ever have to return the vehicle to stock; I spliced in new wire at the doors and ran it to my speakers. I wouldn't consider myself an audiophile, but I do appreciate & have a 'good ear' for high quality sound (I also work per diem doing digital audio mastering, and I've been tinkering with car audio ever since I was 12). I totally understand where you're coming from, though - even if it sounds great, it will still bother you knowing that the factory wiring is still in there. It bothered me for a bit as well, but I eventually got over it as I was very pleased with the final product
I've noticed your other thread. I'll be following it to see your progress and what you end up doing. Good luck with the install. If you have the time, you can do it, even if it requires drilling or re-pinning the molex. Where there's a will, there's always a way.
. I've noticed your other thread. I'll be following it to see your progress and what you end up doing. Good luck with the install. If you have the time, you can do it, even if it requires drilling or re-pinning the molex. Where there's a will, there's always a way.
Oh, and yes, I will be documenting my build to some degree once it is complete. I am not as fanatical as some on the board here but I will try and give you guys some eye candy. I know I get more out of the pictures than anything else when others post.
Yep, sometimes it's best to handle things like this on your own. At least you can rest assured that it was done properly and to your liking. As far as re pinning the molex, I am not sure where to begin in that regard. I searched for "molex tool" on amazon, and a few things actually came back:
http://www.amazon.com/s/ref=nb_sb_no...rds=molex+tool.
I would probably try to find a spare molex at a junkyard and see if you can extract / salvage any pins from it.
Pictures would be definitely appreciated. Looking forward to your build thread.
I am waiting for the parts guy at Infiniti to get back with me on the connector. I asked for part numbers for the connector, pins and whatever removal tool I will need. Basically, if I can find some unused pins on the connector, as long as I have the right tool, I can do without getting another plug or more pins.
photocat
Sep 3, 2015 01:46 PM
