Help Streaming Spotify on 2012 g37X w/ Nav via Andriod
Old Oct 15, 2014 | 09:17 AM
darcyrenee08's Avatar
darcyrenee08
Question Streaming Spotify on 2012 g37X w/ Nav via Andriod
I just purchased a 2012 g37x coupe w/ nav, and I cant seem to figure out how to stream spotify via bluetooth.
My Galaxy S5 has no problems calling and receiving calls through the system, but when I try to stream audio, nothing happens.
Anyone else having this issue? Am i just doing something totally wrong?
Old Oct 15, 2014 | 09:25 AM
ay37's Avatar
ay37
Not sure which part you have to do here, but it's either the case that you probably have to go into your S5 bluetooth settings, then find the connection you are paired with (should be MY CAR by default) THEN click the little "gear" next to the name so you can access that bluetooth connection setting, then check the box that says "media audio" ..... OR it's the case that you have to setup the audio in your car. In the vehicle's bluetooth settings menu, you should have an area where you have to add an audio device in there. It may just be a matter of clicking your phone that you are already paired with on your nav screen. It may have a "greyed" out bluetooth icon next to your phone name, and if you just highlight over it, it should let you hit "select" and it will become your default audio device. Again, there's 2 spots you need to check: the phone in the bluetooth settings and the nav in the bluetooth settings. I hope this helps. If not, I can come back at you with screenshots later lol
Old Oct 15, 2014 | 10:14 AM
darcyrenee08
Great. Ill try that out and let you know.
Thanks so much! Im very slow at this technology thing!
Old Oct 16, 2014 | 01:17 PM
darcyrenee08
That worked! Thanks!!
Old Oct 16, 2014 | 07:57 PM
ay37's Avatar
ay37
Nice! Glad to hear that =)
delfinparis
Oct 8, 2015 06:06 PM
gdaelemans
Sep 13, 2015 09:36 PM
Glen Roebuck
Aug 26, 2015 02:42 PM
drkashifa
Aug 18, 2015 04:38 PM
