Switch 12 volt source
Old Aug 26, 2014 | 03:38 PM
OLPEMI's Avatar
OLPEMI
Hello,
Last weekend, I installed the Kicker Hideaway. It is a small powered amp speaker. Keeping the long story short, the unit doesn't always kick and the switch turns red meaning there is an error.
So, I called Kicker and found out that I didn't install one blue wire.
The agent told me to tap the blue wire to Switch 12 volt Source.
He said it is a source that turns on when the ignition is on. Right?
Where can I find this Switch 12 volt source? or where do you recommend me to install it?
Thanks!
Old Aug 26, 2014 | 04:04 PM
CRiME's Avatar
CRiME
On my '11 with bose, I found that pin #20 in the b41 harness provided switched +12v power. It is a white wire. If you haven't done so yet, have a look at these excellent pictures, courtesy of gsteigerwald:
Old Aug 26, 2014 | 05:50 PM
JT2014's Avatar
JT2014
It may or may not have enough power to trigger the amp. If you have too you can run the remote wire to the drivers side fuse box & splice into the 15amp 12V socket fuse. I had to do this with my Kicker amp.
Old Aug 26, 2014 | 05:53 PM
OLPEMI's Avatar
OLPEMI
If you don't mind, can you show me a picture of your fuse box?
vamarris
Dec 9, 2018 11:10 AM
GeezerB
Car Care & Detailing
12
Jan 23, 2017 07:00 AM
Upscale Speed
Dec 26, 2015 08:45 AM
parkern
Oct 1, 2015 10:15 PM
Chappedj
Sep 28, 2015 03:20 PM
