Help Grounding Kit
Old May 26, 2014 | 02:25 AM
kkokko's Avatar
kkokko
Grounding Kit
I recently bought a new battery and the battery post are a little smaller so I'm unable to attach the BB grounding kit in between the clamp as instructed on the negative terminal or it will come loose. I can however put it on the right side of the bolt along side the other grounding wire.
Does anyone know or think there will be any performance hit from doing it this way due to the connection being not as flushed? See picture below...
If not I may try to fix the clamps instead..
Here is what is the recommended spot to place it.
Old May 26, 2014 | 09:49 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
It will not make the slightest bit of difference. As long as you have it connected firmly, your grounding should be the same.
Old May 26, 2014 | 11:15 AM
What he said. ^^^
Old May 26, 2014 | 12:23 PM
kkokko's Avatar
kkokko
Great thanks guys!
optikol
Jan 28, 2016 07:31 PM
Rybitron
Nov 18, 2015 03:11 PM
RexHavoc
Oct 2, 2015 11:47 AM
hamkha1ebay
Sep 28, 2015 02:38 PM
