Help Possible battery drain fix
Buy one of these: Powerall Jump Starter
we would all like a charged battery, but since the car battery goes dead unless you drive 20+ for a full charge, it's nice to be able to start your car without having to wait for triple A. I'd rather have the jumper as an alternative instead of tinkering around with the G programing.
I was at a car show this morning and a person with a 5.7 litre Corvette had a dead battery. The lights wouldn't even go on. The Powerall started it without any issues. This thing is great, I'm going to buy one for my daughter.
No I do not. I just found it by searching for a compact battery jumper. I had the battery go dead 3 times in the past year and was tired of having the problem. This unit will start cars up to 6 months after a charge. As long as you have 3 of the 5 lights green, it's good to go. IMO, it's a great product. I keep it in the trunk with my owner's manual.
Also if you do this mod will alternator start only with engine or even when car is in ACC Position? I am guessing only with engine, either way I like to sit and listen to music while I am not driving and hate the battery dies for that reason, I am going to get a Optima Yellow Top but would also like to get this done so I get maximum power and never have to worry about a low battery
Our alternators only start If you drive the car 10 miles or more, so if you make a lot of short trips like me 5-8 miles your battery might never be getting charged while driving, that's why people are talking about removing a wire from BCM Module that would make alternator always start when you start the car no matter how much you drive St first. In the end my battery will never get charged unless I drive 10 miles and will end up dying if I don't drive it for few days. But the TSB they had on the 2008 I figured the ECM reprogramming probably modified something so the alternator worked a little more often as I had informed them I made short trips.
It's the yellow wire in your ipdm which is in your engine bay
Also I want to mention I had spoke to a Infiniti tech on the Just Answer website before I went and did my TSB and he had mentioned to have dealer also pull that wire for me but dealer refused.
He had said
"Have them disconnect the one wire out of the IPDM that the Ecm uses to control the alternator"
Before I do it I want some input on people that have done this and that this DIY is correct and mentioning the correct wire.
Also what's the proper way of doing this instead of yanking the wire out or cutting it.
