Headlights Flicker With ABS
Old Dec 2, 2013 | 05:54 PM
jktinen's Avatar
jktinen
Anyone notice their headlights "flickering" while the car is under load? I first noticed this when the ABS kicked in driving in snow. Everything with the headlights is OEM.
Old Dec 2, 2013 | 05:57 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
If you're noticing that, a grounding kit may help.
Old Dec 2, 2013 | 06:53 PM
Do you mean when the traction control kicked in?
Old Dec 3, 2013 | 12:15 PM
jktinen's Avatar
jktinen
yes both traction on accel and the ABS when im sliding while breaking... I have a grounding kit already. I was thinking maybe battery or alt.
Old Dec 3, 2013 | 03:43 PM
Check your brake fluid level.
Old Dec 5, 2013 | 08:34 PM
wuix2008's Avatar
wuix2008
I noticed the same issue today while driving on snow when my abs engaged lights flickered. Also when I take off and tires slip traction control kicks in they also flicker.
Old Dec 5, 2013 | 08:38 PM
wuix2008's Avatar
wuix2008
I also thought it might be battery, pick one up today, that didn't work.
Old Dec 6, 2013 | 06:44 AM
jktinen's Avatar
jktinen
Damn I thought battery also... Ill check the brake fluid level but it seems electrical... Going to the dealor soon to have cat replaced and dif fluid changed, Ill see what they say.
Old Dec 6, 2013 | 11:35 AM
wuix2008's Avatar
wuix2008
Please let me know. There's no Infiniti dealership here where I live. The only people that would notice our issue is people who drive in snow. Thanks
wuix2008's Avatar
wuix2008
I also checked brake fluid, all good.
Old Dec 6, 2013 | 11:38 AM
wuix2008's Avatar
wuix2008
Some audi cars also have the same issue.
Headlights flicker when ESP/ABS activated.
Old Dec 6, 2013 | 11:41 PM
awais's Avatar
awais
Happens to my sedan as well. I thought it's something normal.
Old Dec 7, 2013 | 02:26 PM
wuix2008's Avatar
wuix2008
I have a 2008 Infiniti g35x sedan
Old Jan 11, 2014 | 04:51 AM
photopro's Avatar
photopro
noticed the same thing! in snow (buffalo, NY) when i brake a little harder then usual i noticed the driver headlight flicker. I didn't notice on non snow days but i have to check that more, but definitely under a little harder braking in snow. fluids ok, battery 4 years old but it starts fine in the cold snap we had recently... suggestions. Dealer here is a money grab!
Old Jan 11, 2014 | 09:18 AM
MJaga's Avatar
MJaga
I'm having the same issue...don't have a grounding kit installed yet. Has anyone else tried a grounding kit? Or is that just for sure not a resolution?
