My Nav Swap
Old Sep 9, 2013 | 01:14 AM
Corey Kunak's Avatar
Corey Kunak
My Nav Swap
My car is a 2009 G37X With Bose
Navigation head unit from a 2009 g37x With Bose
GPS Antenna from kenwood (Amazon $24.99)
2008 G35 Nav Harness for Pigtails.
Well this is the first ting i have done to my car. it took around 9 hours today to do started at 11 am making the harness and at 7 the car was 100% functioning.
i made harness so i did not have to splice all the wires. in the end i only think around 4 where spliced (BT Mic Ground etc.)
here is a little video (it kinda sucks the video) . will make a diy when i have time
2009 Infiniti G37 Navigating Swap - YouTube
Old Sep 9, 2013 | 01:40 AM
speedracer g37's Avatar
speedracer g37
wow. nice
Old Sep 10, 2013 | 02:24 PM
Corey Kunak
Some photos of the harness part 1
Attached Thumbnails My Nav Swap-img_0023.jpg   My Nav Swap-img_0024.jpg   My Nav Swap-img_0025.jpg   My Nav Swap-img_0026.jpg   My Nav Swap-img_0027.jpg
Old Sep 10, 2013 | 02:25 PM
Corey Kunak
Some photos of the harness part 2
Attached Thumbnails My Nav Swap-img_0028.jpg   My Nav Swap-img_0030.jpg   My Nav Swap-img_0027.jpg
Old Sep 11, 2013 | 04:20 PM
michg37's Avatar
michg37
nice, I went the wire splicing route but this works just the same, less time with your car ripped apart. Since I spliced the connectors directly my car was in pieces for about 3 days. Did you have any issues fitting all the wiring behind the stereo, mine was pretty tight but your setup looks to be a little worse
Old Sep 23, 2013 | 11:07 AM
jbregar's Avatar
jbregar
So, to do this what parts do you need? I assume the following:
- Nav head unit
- Nav faceplate
- Nav control panel
- Nav screen (since the non-Nav isn't a touchscreen, right?)
- Nav wiring harness
That about right?
Old Sep 26, 2013 | 08:31 AM
Corey Kunak
on the left side of the dash there is an gap with space. i just shoved everything in there. it was a little tight but fit with no issue.
Old Sep 26, 2013 | 08:35 AM
Corey Kunak
- Nav head unit
- Nav faceplate
- Nav control panel
That about right?
yes thats what you need if your going the splicing route (cutting into dash harness)
or if your doing to do it the way i did
old radio for connectors
wire
butt connectors
shrink wrap
soldering iron
Nav head unit
Nav faceplate
Nav control panel
Nav screen
Nav wiring harness
Old Sep 26, 2013 | 03:15 PM
michg37's Avatar
michg37
- Nav head unit
- Nav faceplate
- Nav control panel
That about right?
you'll also need GPS antenna for Nav to work
Old Sep 26, 2013 | 03:18 PM
quakerroatmeal's Avatar
quakerroatmeal
Since you were going to do all that. Why not opt for the better 2010+ nav setup?
Old Sep 27, 2013 | 08:32 AM
Corey Kunak
i was unable to find a 2010 unit.
i also think that the dealer would not notice a 2009 nav in a 2009 g37
Old Dec 31, 2013 | 01:11 PM
DJMAC's Avatar
DJMAC
If you have a 2009 w/bose no nav and want to do the swap could you use the pigtails from a 2008 nav g37?
I have all the pieces from a 2012 navigation g37 except the dash wiring harness. I'm assuming you need a 2010+ wiring harness as its a new digital screen etc etc..
Good to know the kenwood gps antenna works the same as the $180 infiniti one
Old Jan 3, 2014 | 09:52 AM
Corey Kunak
Yes you can use the pigtails from a 2008 if you want to put a 2009 Nav in.
If you want to install the 2012 nav screen your correct you will need the new harness that includes the new display connector.
Old Oct 9, 2014 | 05:23 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
Something about this statement gives me the warm and fuzzy feeling that I bought my car new...
Old Oct 19, 2014 | 05:18 AM
hechen507's Avatar
hechen507
Does your mic work for touchfree? From what I have seem you need to route wires from the TEL unit to the new AV unit since the NAV AV unit has TEL controller built in and none nav does not.
