My Nav Swap
Old Oct 23, 2014 | 02:26 AM
homer626's Avatar
homer626
Really clean swap!
Old Mar 9, 2016 | 12:47 PM
Chris0831's Avatar
Chris0831
Non navigation
I want to upgrade my non navigation g37 to navigation my question is this. Is they sell the. Adapted cable Or I need to change my Dash harness
Old Mar 11, 2016 | 04:14 PM
Kris9884's Avatar
Kris9884
Since you were going to do all that. Why not opt for the better 2010+ nav setup?
There's several on eBay now, what's the big difference besides the obvious price jump?
Old Mar 13, 2016 | 12:21 PM
Chris0831's Avatar
Chris0831
I have a 2011 G37 with no navigation I want to add navigation the car has boss system and XM radio back camera do you know anybody in Texas can do it I live on houston someone that can make the harness sell it to me
Old Jun 24, 2018 | 04:59 AM
zmann96's Avatar
zmann96
2009 G37 2013 Nav system
I was reading this thread. I have my 2009 G37 without the NAV and have purchased a 2013 Nav head unit, 2013 controller, 2013 screen and the GPS antenna. Is there a wiring harness that I can purchase to connect the new system so everything works? will most of my plugs, plug into the 2013.
Old Jun 24, 2018 | 11:46 AM
ILM-NC G37S's Avatar
ILM-NC G37S
There is no wiring harness that you can buy which will make this swap plug-and-play. You will either have to make one yourself or modify your existing harness accordingly. If you are skilled working with electronics than this should be a easy project whichever method you go.
That said, most of the existing connectors will be reused, however, you may need some different connectors for the 2013 system. There are quite a few threads here on the forum regarding the swap and all that is involved.
Good luck.
Old Jun 25, 2018 | 11:30 AM
zmann96's Avatar
zmann96
Thank you
I do decent at following directions but to figure it out from scratch I'm not sure if I can. I guess it depends on how many plugs will work and how many are left and what they are used for. I've found in the past that the color codes vary quite a bit and that has thrown me off. I guess once I start and am having trouble I'll start to read more posts. Thanks again for your response.
Old Jun 26, 2018 | 04:45 AM
zmann96's Avatar
zmann96
Diagrams for Infiniti's
In looking for the diagrams that I need I found this and thought I'd share it. BBBind dot com / tsb - wiring - diagrams /
Old Apr 19, 2021 | 09:16 AM
OWC's Avatar
OWC
To anyone interested in pursuing this upgrade / conversion. Here's some useful info I put together with a list of parts needed to convert. Also offering brand new plug-n-play harness kits.
https://www.myg37.com/forums/audio-v...ion-setup.html
Ryan Peterson
May 31, 2019 04:00 PM
LakewoodG37S
Dec 28, 2017 01:37 PM
GFTW
Jan 16, 2016 04:19 PM
DJMAC
Oct 10, 2014 01:30 PM
stvsfx
Jun 22, 2013 12:30 PM
