Climate control acting strange
Old May 29, 2013 | 11:27 AM
jaykellogg's Avatar
jaykellogg
My climate system stays set at 75°. If the outside temp is 62° it is stuffy inside and if the outside temp is 90° than it blows real cold. It seems to me that the inside temp should be controlled at what it is set. My last car (only other car I have owned with climate control) was a Nissan 350Z roadster and the climate control kept it at a comfortable 75° even though it was a roadster.
Old May 31, 2013 | 08:31 PM
g37guy01's Avatar
g37guy01
seems like a no brainer. What model car. In my 2011 g37x sedan the climate control works as expected.
Old May 31, 2013 | 10:12 PM
jaykellogg's Avatar
jaykellogg
Originally Posted by g37guy01
What model car.
A 2008 G37S coupe.
Old May 31, 2013 | 11:44 PM
alanz's Avatar
alanz
Same issue for my '12 X sedan. Well not sure if it is an issue.
Old Jun 1, 2013 | 12:05 AM
RISKY GUY's Avatar
RISKY GUY
I can tell you from owning an 08 coupe.
The a/c can't be on 75 if its 62 out, it's not gonna keep it cold.
Drop it down to 65-70,then try it.
Remover being stuck in dead traffic on 95 degree day, a/c was brick cold.
Unless your maybe low on freon?
Old Jun 1, 2013 | 06:11 AM
jaykellogg's Avatar
jaykellogg
No, on a hot day the AC is cold. It seems strange that my 2004 Nissan 350Z roadster had better climate control than this.
Old Jun 1, 2013 | 07:47 AM
RISKY GUY's Avatar
RISKY GUY
It's not that it was "better" it is less sophisticated in the z.
I noticed anything I set over 70, was never cold enough.
Used to set 65-70 then adjust up or down a bit.
IMO it's the auto climate control on the 08s.
vamarris
Dec 9, 2018 11:10 AM
2K1 6T8
Oct 6, 2015 07:40 PM
EnYcee-G
Oct 4, 2015 09:27 PM
Landshark
Sep 29, 2015 11:20 PM
cshawsg37
Sep 25, 2015 05:33 PM
