Flickering headlight. Not bulb. Fuse? Ballast?
Old 10-04-2012, 08:30 PM
tristanbane
tristanbane's Avatar
Hey guys,
My passenger side's headlight has been flickering then shuts off after each time I turn the lights on. Initially thought it was the bulb so I got a replacement set (since I was gonna change bulb color/temp anyway). I've tested the bulbs on the same side and still the same results, so it's not the bulbs' fault.
Could it be the fuse or the ballast?
If it was a fuse problem, wouldn't the light just NOT turn on at all instead of flickering then off?
So I'm thinking it's the ballast. What do you think?
If it is the fuse, how do I get to it? I thought it was the small box posterior to the battery in the engine bay, but after doing some research, it sounds like there's another fuse box in the battery compartment??
Thanks in advance!
Old 10-04-2012, 09:32 PM
Weiboy718
Weiboy718's Avatar
Originally Posted by tristanbane
Hey guys,
Thanks in advance!
Good chance it may be your ballast starting to go out, and if the fuse pops it would never turn back on again till you replace that. One way you can confirm that it's the ballast would be swap it to the other side and if it's the same thing then for sure it's the ballast.
Good luck!
Old 10-05-2012, 04:05 AM
unknowndesi
unknowndesi's Avatar
just like wei said... swap them but before you swap them try pushing the wires into the connecter harness
Old 10-05-2012, 04:40 AM
tristanbane
Good luck!
Thanks for the tip! Looks like it couldn't be the fuse since it does turn back on, just doesn't stay long. I'll try the swap and see what happens, since I've only swapped bulb TYPES, not bulbs Left/Right. (if that makes sense haha)
Also, I've seen your ride on a couple of threads! Very nice! Wish I could've gotten a hold on a white G but couldn't pass on a decent deal for mine
Thanks! I think I have tried what you described in the second part. I tried moving the harness/connector around and all but still same results. Will try the L/R bulb swap next.
Old 10-05-2012, 08:20 AM
Can'tGme
Can'tGme's Avatar
This may be the same problem I'm having. I just recently painted my lights and about a month after I painted them I started having passenger bulb problems. When the lights come on automatically the passenger side will flicker and go out. If I turn the lights off and on again sometimes it will come right on, but most of the time it takes a few attempts.
Old 10-05-2012, 08:27 AM
tristanbane
Yes! That's exactly my problem!
Sometimes I do the "off/on/off/on" method where I feel like I'm working with a sparker, it would stay on but then go out again minutes later... It's kinda embarrassing on the road lolll suddenly one light goes off...
Old 10-05-2012, 08:33 AM
Weiboy718
Weiboy718's Avatar
Where in NORCAL are you located at?
Old 10-05-2012, 04:49 PM
tristanbane
I'm from the Lodi area. Way inlandd. You?
Old 10-05-2012, 06:01 PM
Weiboy718
Weiboy718's Avatar
Haha. You are out there, I'm in SF
Old 10-06-2012, 10:29 AM
nkG37S
nkG37S's Avatar
def sounds like its the ballast.
Old 10-09-2012, 05:07 PM
iam8up
iam8up's Avatar
I believe fuses are binary - working or not. They don't flicker or anything. I agree, ballast is the most likely answer.
Old 10-16-2012, 06:03 PM
auburnjim
auburnjim's Avatar
anyon
passenger side headlight out. replaced bulb stillout. Is there a fuse? if so where is it? Other ideas?
Old 10-16-2012, 07:28 PM
nkG37S
nkG37S's Avatar
Originally Posted by auburnjim
anyon
its the BALLAST...
Old 10-17-2012, 01:56 PM
auburnjim
auburnjim's Avatar
Headlight problem
nkG37S
Thanks for reply
auburnjim
Old 10-17-2012, 09:14 PM
nkG37S
nkG37S's Avatar
no prob man!
Quick Reply: Flickering headlight. Not bulb. Fuse? Ballast?
