Infinity basslink installed - mini review
Old Sep 15, 2012 | 05:16 PM
blazeplacid's Avatar
blazeplacid
I was skeptical about the Infinity basslink.
Mostly good reviews online but the few bad ones made me a little iffy.
In my G35 I had a Tc sounds LMS-R in a 2 cube ported box, powered by a nine.1 Roughly 1400rms. It was great but the box took up a lot of room and I didnt want that in this car.
I was looking into an enclosure that would fit in the G37 sedan either in a corner or blend in with the interior some how. The few I found online were around $300 and most shops around me quoted $500+. I needed to maximize space for a stroller, diaper bag, etc. Not that I always have the baby, but when I had the G35 there was no room for a stroller or anything besides a few small grocery bags.
The Infinity brand has always made decent stuff with good prices so I made an order with crutchfield.
Currently Crutchfield offers the bass link with a wiring kit for $200 shipped.
A great deal!! The service at crutchfield is beyond anything you will find with most retailers.
I found a wiring diagram in one of the stickys that had the owners manuals and maintenance guides. It was a GREAT help. I used positaps behind the radio so that I wouldn't cut into any factory wiring. The bass link provides the cables so that you can tap into your factory wiring. The only thing you need to buy are the positaps or something similar.( I will upload the diagram I used later).
I ran the speaker wires and the power wire down the passenger side. No noise issues (that is a myth about the noise when running power and your source signal). Grounded in the trunk and I was ready to go.
Initial impressions This little package is impressive for what it is. It is rated at 200rms but they really make use of the passive radiator. No distortion or any unwanted frequencies. I did have a problem with the ground. I was rushing and basically half assed tightening the ground. After I got that fixed, no issues.
I think most of the bad reviews are from people who either don't know how to install audio properly or just throw it in hoping for block rocking bass. This is not for that. The basslink does its job very well and impressed me. The best part is I keep my trunk space and gain the bass that the factory system is missing.
Here are a few pics. I need to clean up the wiring.
Old Sep 15, 2012 | 07:46 PM
zinfiniti's Avatar
zinfiniti
Looking forward to the diagram and how you used the positaps.
Also, would the basslink have fitted in the sides of the trunk instead where a boxology or 408 box would have gone?? It would be nice if it was flush to the side and completely out of the way.
Old Sep 15, 2012 | 07:56 PM
blazeplacid
For NON bose audio with rear view camera..page 154.
Connector M201 shows you which wires to tap into.
I didnt take pictures but the connector is easy to identify.
See the index for other packages
https://dl.dropbox.com/u/76054624/AV.pdf
Old Sep 15, 2012 | 08:27 PM
zinfiniti's Avatar
zinfiniti
Thanks!!!
Old Sep 19, 2012 | 01:49 PM
blazeplacid
I moved it to the corner where a 4080 type box would go.
Seems a little bit louder in the corner.
Did this on my lunch break so the wires are easily visible.
Old Sep 19, 2012 | 05:02 PM
zinfiniti's Avatar
zinfiniti
It fits!!! That makes it a lot more appealing to me now. Thanks for sharing!
Old Mar 18, 2014 | 11:02 AM
Shabba's Avatar
Shabba
It looks much better in the corner. I'm thinking about doing the same for my G37 coupe. I installed it a while back in my old G35, and you're right. For what it is, it does an amazing job. It's not a Pimp My Ride, neighborhood shaking, bone rattling system. It's designed to complement existing systems, filling in the low end for a richer sound, even at lower volumes.
Old Mar 19, 2014 | 07:39 PM
Darth Kinetic's Avatar
Darth Kinetic
how did you secure it in place?? and where is a diagram for tapping in to preamp Bose for signal? thanks!
Old Mar 20, 2014 | 11:46 AM
blazeplacid
it actually stays in place without needing any hardware.
You can sercure it to the carpet with nuts and bolts if needed.
I dont have this set up anymore but it was a great set up for $200
If you search my user name you should be able to find a post where I uploaded all the diagrams for the bose and non bose audio options.
Old Mar 20, 2014 | 07:31 PM
TVPostSound's Avatar
TVPostSound
The pic is a sedan, wont fit in the corner of a coupe.
Old Mar 20, 2014 | 08:01 PM
Darth Kinetic
I am going to Make mine fit in the side of my Coupe :/
Old Mar 20, 2014 | 08:02 PM
Darth Kinetic
And no way my Spirited driving will allow it to stay without bolting it down
GW330
Feb 2, 2024 05:41 PM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
blazeplacid
Sep 17, 2015 10:50 AM
SS2006
Aug 11, 2015 10:24 PM
VIVID
Aug 3, 2015 02:40 PM
