Help Navtool with 2010
Old Jun 21, 2011 | 04:21 PM
Fezzik's Avatar
Fezzik
Go look at the FSM
Old Jun 21, 2011 | 06:10 PM
prescott3656's Avatar
prescott3656
Originally Posted by Fezzik
Go look at the FSM
I was checking that out yesterday after i sent the box off. It will be very helpful if i can figure out which harness i am looking for in the FSM. That thing is certainly packed with info and diagrams. I wanted to check it to see if the Y harness was wired correctly, although I'm not sure i know what I'm looking for.
Old Jun 23, 2011 | 09:55 AM
prescott3656
since I sent my Navtool off to be replaced, I have been using my navigation system with the Navtool Y-harness still in place. I'm not sure if it should even still work like this, but i noticed my back-up camera is all distorted and no longer adjust for dark lighting as it did before. Time to explore the harness.
Old Jun 23, 2011 | 10:46 AM
Weiboy718's Avatar
Weiboy718
that's weird, the navtool shouldn't affect the backup cam cuz the backup cam cut's off all video signal once in reverse.
Does your screen still show any pictures? I dont think it should show any picture without the box
Old Jun 23, 2011 | 11:03 AM
prescott3656
Yea it still shows my nav/music screen just like it would normally. That's what has me thinking the harness is not wired correctly.
Old Jun 23, 2011 | 12:16 PM
Weiboy718's Avatar
Weiboy718
I'll do a test later by disconnecting the power to the box and see if it still operates or not. That should solve your mystery
Old Jun 23, 2011 | 01:44 PM
prescott3656
Appreciated. Thanks.
Old Jul 6, 2011 | 12:36 AM
Modme's Avatar
Modme
The 2010 Navigation screen is completely different from the rest of the years. You cannot use any of the interfaces designed for 2008-2009. The 2010 interface does not use RGB like all the other years. It uses a digital video signal called GVIF. The only way it'll work is to use an interface box. I am organizing a group buy on the box. See here if you are interested:
https://www.myg37.com/forums/audio-v...ml#post3174373
Old Jul 6, 2011 | 08:30 AM
prescott3656
yep, I'm signed up. Currently waiting for a refund from Navtool. <-- (skeptical it will come) Thanks Modme.
Mr Infinit
Oct 16, 2015 09:43 AM
butwhatuptho
Oct 4, 2015 07:51 PM
arkyv714
Oct 4, 2015 03:44 PM
