Help foot well LED lights
Old Feb 8, 2011 | 02:35 PM
Tuckermaclain's Avatar
Tuckermaclain
If you wire it into the glove box light it comes on when you turn your lights on. The most natural effect, IMO. Studying the shop manual I found no other easily accessable source switched like this. The factory light kits taps into here as well.
Old Feb 9, 2011 | 02:56 PM
bigfazolie's Avatar
bigfazolie
Originally Posted by msmching
Looks good.. but 85 seems to be a lot tho..
i recalculated... 20 for all the interior led's 6 for the switch 10 for the wire and 10 for the battery kit. so it was 46. i thought it was more because we also did his trunk
Old Feb 10, 2011 | 03:19 PM
roots4x's Avatar
roots4x
I justdid this using LEDs from Fry's electronics. They sell jumbo white 10mm LEDs that give off a perfect amount of light if you're going for a dim ambient look.
I tapped into the glove box light and used computer fan connectors to make the installation more modular and professional. I aimed the lights at about a 30deg angle down using hot glue as a mount and zip ties to secure the LED. To use the zip ties I drilled two small holes into the lower panel so I could secure the hot glue and LED mounting.
I also used adhesive felt to cover all wires and mountings to prevent any possible squeaks or noises down the line.
Total everything cost about $25 (wires, LEDs, felt, quick release connectors, hot glue) and I am very happy with the turnout.
Rayramg37
Nov 18, 2015 09:06 AM
Gefartenblatz
Nov 10, 2015 11:45 AM
misc
Sep 14, 2015 05:16 PM
B Feelgood
Sep 13, 2015 05:56 PM
pauliewalnutzz
Sep 8, 2015 11:41 AM
