How to play movies via USB
Old Nov 16, 2010 | 07:18 AM
CryofMankind's Avatar
CryofMankind
I wrote this up in another thread and thought it would be helpful to have it as a standalone post.
Here are the steps you would need to follow to convert existing movies to be able to be played via the USB port.
  1. Download Xvix here (find the right one for your computer)
  2. You will need to have a DIVX codec installed on your computer - if you are able to play movies, chances are you are all set. If not, download one (I'd suggest the CCCP or you can download just the DIVX Codec here.)
  3. Go to the install directory (default is C:\Program Files\Xvid) and run the file called AviC.exe
  4. Hit the [...] button to browse for your movie file.
  5. Set the second box to DIVX and hit Apply
  6. Now, copy this file onto a thumb drive (or in my case a Solid State Hard Drive) and put it into your USB drive in your car. Make sure your parking brake is on, and you should be good to go.
This is the 64gb SSD USB drive that I use:
Newegg.com - A-DATA S596 Turbo AS596TB-64GM-C 2.5" 64GB USB 2.0 & SATAII Internal / External Solid State Drive (SSD)
Hope that helps!
Old Nov 16, 2010 | 07:49 AM
ScottyBeGood's Avatar
ScottyBeGood
again... very helpful information.
Old Nov 16, 2010 | 09:53 AM
carz's Avatar
carz
thanks for the writeup, i wasnt sure this was possible.
Old Nov 16, 2010 | 02:28 PM
Staples's Avatar
Staples
Very good information! Now I can watch my episodes of Glee on my break at work!... Wait what?
Old Nov 16, 2010 | 11:36 PM
MiniRX7's Avatar
MiniRX7
Very similar to my original thread!
https://www.myg37.com/forums/audio-v...vid-files.html
Old Nov 17, 2010 | 04:13 AM
CryofMankind
Hey MiniRX7,
Didn't mean to poach your thread - I probably should have searched the forums a bit more, but I didn't notice anything like this around before. I figured something like this would have been stickied.
Old Nov 17, 2010 | 09:10 AM
wakeboardr116's Avatar
wakeboardr116
Will it play any other formats? I hate xvid/divx
Old Nov 17, 2010 | 09:13 AM
CryofMankind
I hooked up my 2tb drive initially (it has several hundred movies in all different formats). It will display all on the screen without a problem, however when you go to play them, it will say something like "unrecognized format". It appears that only Divx is a recognized format - anything else won't play. Reading through the manual last night, it also appears that they say only the Divx codec is recognized. I did find out that the raw files from a Cisco Flip HD video camera play just fine...
Old Nov 28, 2010 | 05:22 PM
MiniRX7's Avatar
MiniRX7
I tried to use an SSD HD as well 64gig, but the system seems to forget that it has connect to it before, and then resets.
Going back to 16gig USB stick instead.
Old Nov 28, 2010 | 08:48 PM
CryofMankind
Was it formatted as FAT32 or NTFS??
Old Dec 3, 2010 | 04:41 PM
UNCTYPE-S's Avatar
UNCTYPE-S
Is it only for G's with NAV or can it be done with Non NAV?
Old Jan 3, 2011 | 02:43 AM
steve1234's Avatar
steve1234
thanks for writing.... really like it and appreciate your effort too
Old Jan 3, 2011 | 06:30 AM
mightymousehhd4's Avatar
mightymousehhd4
OH JOSH.....opening up a can of worms with that one....that's prob why you didn't get a response the first time.
https://www.myg37.com/forums/audio-v...t-allowed.html
Old Dec 11, 2011 | 04:17 AM
NissanTech's Avatar
NissanTech
Hope that helps!
Can this work on a non-nav G37S sedan 2011?? Thanks, i want to play videos in my car too!
Old Dec 11, 2011 | 02:42 PM
Tazicon's Avatar
Tazicon
Pretty sure the answer is no but I could be wrong
