Changing time on Navigation & what is drive-b?
Hi I have two questions and decided to ask them both in one post.
1)How do you change the time on the Navigation/Radio Screen? Mine seems to be one hour behind at the moment.
2)I see Drive-b (D-b) and another Drive when changing gears. I've been driving on Drive-b. What is the difference between the two?
Thanks.
Thanks.
For #1, I would guess you either need to change your time zone, or set daylight savings time. I believe the time should come from the satellites, so it should be good otherwise. Those are both changed in a menu on the Nav. Being at work, I can't look through the Nav Manual or the Nav menus at the moment to find the exact buttons.
If you are an hour off it is likely that you have the option set to 'correct for daylight savings time' or something like that. Just go into the options screen and see if that is checked. If it is, then you might want to turn it off and see if that takes care of the issue for you.
Not sure what Drive 'B' is. As previous posters mentioned - I've only seen D or DS (not B). Drive 'S' or sport is a setting that makes the transmission shift more agressively (and a lot more fun) without having to shift 'manually' with the paddles or the gear shifter. Works pretty well too!
Jayk
Jayk
superjoey
31
Mar 22, 2023 11:56 PM
