Great work, wogboy. Looks very nice. Did you keep the factory speakers in the doors, rear deck, and dash? If so, how are you splitting the output from the 5 channel amp to the appropriate source (Woofer, Mid, Tweeter in the door for example)? Are you using a passive 3-way crossover on the amplified side? Also, did you do away with the center speaker in the dash?
I've replace the front door speakers with a new pair of splits, the mids are not used. The centre speaker I now use only for the sat nav. I also replaced the rear woofers with a pair of 6 x 9 3 ways and don't use the the speakers near the b pillars. Hope this covers it, if not please ask more questions.
Cool. Thanks for the feedback. Which splits did you end up using in the front stage? Did it require much modification?
The whole sysem is Option Audio, Amp, Sub (changed since the photo's) rear 6 x 9's and splits. The tweeters basiclly replaced the OEM one's and for the woofers I made some adapters to bring the size back down to suit 6" woofers.
Did have pic's of the mod's but I'll be F@#$ked if I can finf them! I'll keep lookin' but.
