Preliminary install pics (warning, pic heavy!)
Ok, so here are some preliminary pics of the install. It's not 100% show ready yet but functionally complete. You can see the car was gutted to install 2 large boxes of Hushmat. There are NO rattles. Although missing from the pic, I did complete doing under the rear seat which you currently still see as grey.
This is the trunk install with LED under lighting. I still need the box trim, lexan window over the amps and carpetted floor panels.
Speakers didn't fit in the old 6x9 space so we did a custom deck lid. Anyone notice the Bose plate over the speaker functionally covers a lot of it? Doesn't even give it a chance to sound like it should.
My baby!
Custom box with dual Mille 10" subs. We cut the logo ourselves to be raised in the vinyl.
BitOne placement over the old Bose amps.
Removed the ashtray to put the BitOne DRM controller in.
I should have the finished pics soon (as I finish it).
My baby!
OOOOOOOOO
Such great equipment! Lookin great so far. How long did it take you guys to take everything out and apply the Hushmat?
Do you have pics of the front speakers (mids) before the door trim is put back on?
Subscribed for final pics!!!!!! You should also add your "lessons learned" stuff (from the other thread) into this one since the pictures have a tendancy to draw people...
Yeah there are more pics coming (my brother has most of them). It took about 20+ hours to gut and Hushmat the car and put the seats back in. Doing the backseat/rear deck alone was 8+ hours AFTER the seat was out. I don't want to see Hushmat for a while, lol! But worth every minute, it's pretty easy but tedious to be thorough.
From my other thread, here's what I learned so far:
-make sure the BitOne has the latest v1.5 firmware
-use a proper ACC line for the remote/key in or you might have funny power on issues (mine sometimes stayed on and killed my batt. so lesson learned)
-use the low level pre-amp lines or you might find alternator noise and de-EQ issues with the Bit (I did)
-I'm running the factory battery with no power cap
-every required signal is already in the trunk!! fantastic!
-the factory harness has plenty of room for 1/0 wire down the passenger side. It takes but seconds to run it.
-when running the BitOne setup you can have the factory HU at max volume since it doesn't clip
My biggest headache was finding out the keyed power isn't 12V. That caused hours of issues. And you can safely remove the Bose and factory sub amp completely from the car and lose nothing.
Here's a couple other pics (sorry some of these came out blurry, they were taken on a couple different phones):
New deck lid plate since the speakers couldn't drop right into the 6X9 holes...
Finished rear deck lid!
Distribution block in the trunk. We side lit it with LEDs
Poor focus night shot of the unfinished trunk
In dash DRM controls.
That rear deck looks great! But those 6.5's in the door look so small!!! lol luckily it's all covered up and then it's only the sound that counts.
Are you able to close the ashtray door so you can hide the ausion controller to keep thieving eyes from getting too happy at what they see?
Hey, I was wondering if you could help me out..
I just got my system installed yesterday. Exact same as yours except no rear fill and a JL 10w6 instead. I feel the installers aren't as great with the bitone as they seemed to think.. They set preset A for me (time alignment, x-over, eq) saying that when it was cranked to 0db this was the loudest unclipped signal that the speakers could handle.. As of now, preset is A is VERY slightly clearer than the untouched presets, but it isn't as loud, and the sub barely plays...
I know these speakeres can go louder... and sound better than this.
Could you give me a breakdown of the settings you have tuned on your LRx5.1? And a basic breakdown of x-over points/slopes you used?
Thanks so much if you/anyone can help me out!
- Check the levels they have set for each channel, are they as high as they can go? (not that necessarily they should be)
- Of course make sure the HU is cranked to max volume
- If you have access to a scope, disconnect the speakers and measure the amp output. Crank the gain until the sound clips (best if you have a tone CD), then turn it back a little to pre-clip. The shop should have done this, Audison requires it from people that carry their gear.
- Set the Dynamic Equalization in the BitOne. This can really help bass, etc. at low levels. Set the EQ to how you want it sounding at low level, press Save. Repeat at max volume and Save. The Bitone takes care of everything in between (might help with the bass issue).
- If you have the same amps, what are you getting for output voltages?
I your box sealed? I found the lows got a lot richer after filling it 2/3 with Polyfil. If it's ported nevermind.
