My audio setup on my G37 re done for the 3rd time
Old Mar 22, 2009 | 02:01 AM
Lou@Amplified's Avatar
Lou@Amplified
Thumbs up My audio setup on my G37 re done for the 3rd time
We have changed my baffle board again for the free air setup to make it more show worthy. The first setup was a simple board bolted on the rear deck using MDF 3/4 INCH with some fiberglass resin to make sure there is no flex, then wrapped with white carbon fiber vinyl.
List of awesome equipment. SQ worth system but we just don't have time to try to compete
MOREL ELATE 3 WAY COMPONENT replaced the 3 way bose system
- all other bose speakers and factory amplifier was removed
ZAPCO DC REF 1000.4 bridged to power the Morel Elates 500w each side
ZAPCO DC REF. 750.2 bridge to power 2 10 inch IMAGE DYNAMICS IDQ V.4 wired in series
Here was the original setup from last year HIN
Both baffle board and amp covers wrapped in white carbon fiber vinyl
Here was the 2nd setup we had for SEMA 08. We changed the amp cover, made it smaller, added the MAGDEN COMPUTER and some blue LED LIGHTS
Here's the most recent setup. Basically changed the baffle board, made out of fiberglass and with the burch wood rings to make it lighter since they are lighter than MDF. Alot more work but it sure looks cleaner. Also, the subs are now facing the truck instead of the cabin. Sounds exactly the same as the old setup but it seem to me that i can adjust the base frequency a little lower for lower bass instead of the tight bass. Added brighter LED'S too. I will post more pictures of on how we made the new sub baffle fiberglass board.
If you are local to us and would like us to assist you in any way regarding audio build, same as this or similar, let us know
thank you
AMPLIFIED MOTORSPORT
Old Mar 22, 2009 | 04:26 AM
graphiteg37's Avatar
graphiteg37
Wow. Great work as usual Lou!
Old Mar 22, 2009 | 05:04 AM
jnguyen's Avatar
jnguyen
WOW wish i was local so i can let ya install a audio system and my magden like that for me lou. So.cal get all the good stuff lol but anyway Nice setup.
Old Mar 22, 2009 | 05:12 AM
STOOF's Avatar
STOOF
Nice setup!
Old Mar 22, 2009 | 02:29 PM
aliiin's Avatar
aliiin
BMW Defector
looks good....
Old Mar 22, 2009 | 04:07 PM
g37mobbber's Avatar
g37mobbber
dam that looks good...can you send me a p.m. on how much you would charge for a custom box for two 10" subs plzzz =]
Old Mar 22, 2009 | 10:39 PM
Lou@Amplified
Did you want the same setup as this or something different??
Old Mar 23, 2009 | 03:16 AM
xyz's Avatar
xyz
dang that is one awesome setup . . .
Old Mar 23, 2009 | 12:27 PM
Triple_X's Avatar
Triple_X
nice looking setup. that must POUNDDDDDD. Probably make me throw up if I sat in the backseat
Old Mar 23, 2009 | 12:40 PM
Graham's Avatar
Graham
How's the impact sound, or "bump" without having the box to give you the sealed airspace?
Old Mar 23, 2009 | 12:46 PM
jnguyen's Avatar
jnguyen
Looks great. I pm'd ya lou. Looking to do something exactly like this for my car.
Old Mar 28, 2009 | 03:55 PM
donpisto's Avatar
donpisto
Wow, never seen an infinite baffle done like that. How does it compare to having it the original way? Any plans on going with an active crossover in the future?
Lou, I'm not sure if you used Birch Plywood or some grade A birch (ie: Baltic Birch). If you plan on re-doing this again in the future, and if you used birch ply, look into Trupan. It is MUCH lighter than MDF, but has the same strength properties. I think it may also be called MDF Light, or something like that.
From the few infinite baffle setups I've heard, you would be surprised. Going with this route, the sub needs half the power you normally would. Low end frequency response is greatly improved. Setups like these can get quite loud if you want as well. I'd go this route, especially since I'm considering adding another 15" to my setup, but it's a PITA to seal off everything. If you don't seal back waves from front waves, it's going to result in cancellation and sound like poo. When done right, it saves space, weight, and sounds awesome.
Old Mar 28, 2009 | 07:43 PM
Lou@Amplified
Graham,
stop by the shop and listen to it. You'll be surprised
Old Mar 29, 2009 | 01:34 PM
w0ady's Avatar
w0ady
very clean. your trunk still looks huge with that setup. i think you should fill in the outer sides of the subs though to flow better with the trunk.
Old Mar 30, 2009 | 06:48 PM
Lou@Amplified
I thought about that but then it would look too close to the zenclosure box. I decided to do it this way so it has more of a custom look, i guess something different
