Is that right? I thought he was kidding...Even if is right, it won't be too helpful. Although it'd require no mod, it's not really fast in case one would need to catch an event quick...
It works. But not practical. Make sure don't screw up your "wheel position lines" alignment ( the green lines that shows where you will go when you reverse the gear) when you are playing with it.
