Optima Yellow Top, which model?
Old Nov 6, 2008 | 03:40 AM
Dz Nuts's Avatar
Dz Nuts
Did a search, but couldn't find reference to the specific model we need.
I am doing the big 3 upgrade, adding a cap, and want to also move to an Optima Yellow Top.
Does anyone know which model is best for the G37?
Thanks,
DN
Old Nov 6, 2008 | 10:37 AM
Graham's Avatar
Graham
We have a tiny battery is all I know. If you really want a yellow top you may have to consider mounting it in the trunk.
Old Nov 6, 2008 | 04:56 PM
jadams's Avatar
jadams
According to Optima yellow should fit. I am looking at this battery also since my second Infiniti battry is going dead.
http://www.optimabatteries.com/find_...tery_popup.php
Results - Group Number: D35 (8040-218)
YellowTop®; Deep Cycle Battery; Grp. D35; Cold Crank Amps 650; Crank Amps 810; Reserve Capacity 98; Amp Hour 48; Top Terminal; L-9 5/16 in.; W-6 3/4 in.; H-7 5/8 in.; UNBOXED;
corner
Price at Amazon $174.12.
http://www.amazon.com/Optima-Batteri...6008203&sr=8-1
Old Nov 9, 2008 | 12:21 AM
Dz Nuts's Avatar
Dz Nuts
corner
Thanks very much!
After you provided this information I did a quick check versus the Braille battery and have now decided to go that route. Looks like the two batteries have almost the same specs with the Braille showing much better weight reduction.
DN
Old Nov 9, 2008 | 12:53 AM
NeverBoneStock's Avatar
NeverBoneStock
Originally Posted by Dz Nuts
Thanks very much!
DN
Go to my 350z.com and do a quick search on both batteries .. Lots of good info .
Old Nov 9, 2008 | 05:00 AM
Dz Nuts's Avatar
Dz Nuts
Replied in the other thread.
Thanks for the heads up.
Old Nov 13, 2008 | 10:40 PM
BocaCoupe's Avatar
BocaCoupe
Yellow battery is NOT intended for use as your main (STARTING) battery. It will eventually warp and not work. I would get a REDTOP optima. This is from my experience.
eljoker
Future Models
19
May 30, 2022 11:48 AM
2cold
G37 Convertible
12
Oct 27, 2015 02:05 AM
xx7sephiroth7xx
Oct 15, 2015 01:44 AM
steven92
Sep 18, 2015 12:04 AM
