installing my amp HELP!!!
Old Aug 1, 2008 | 09:07 PM
shepa's Avatar
shepa
hey guys!
im insalling my subs/amp today and have finished getting my power cable through the firewall and into the trunk (took me forever to find the hole in the firewall).............. soo now its time to hook up the audio cable to the head unit..... my question is can someoen please please tell me how to remove the head unit to installl the cables!!
Old Aug 1, 2008 | 09:45 PM
oOmikeyboy's Avatar
oOmikeyboy
I don't think its necessary to pull out the head unit... because our head units dont come with pre-amp outputs anyways.
The best thing to do would be to look next to the spare tire, there is the stock bose amp, splice into the rear speaker wires before it goes into the stock amp, and use a line output converter to convert it into RCA's.
Its either that or use the built in line output converter thing thats in some amps, like the JL 500/1...
I'm pretty sure this is how it works for our cars, correct me if im wrong
michael
Old Aug 1, 2008 | 10:18 PM
shepa's Avatar
shepa
so i would just strip a part of the wire going into the stock amp withou even having to remove it and tie my line out converter wire to i and then just cover it in electrical tape.
thats alll i would need to do to splice the wire?
Old Aug 2, 2008 | 12:21 AM
oOmikeyboy's Avatar
oOmikeyboy
Yep, look up the wiring diagrams for your car, and then do this. assuming our wiring is the same as a g35:
http://g35driver.com/forums/1188712-post4.html
Old Aug 2, 2008 | 12:59 AM
]\[ /-\ ]\/['s Avatar
where can we find wiring diagram for our car?
Old Aug 2, 2008 | 01:15 AM
EZDozzit's Avatar
EZDozzit
No Soliciting
You can download the Factory Service Manual from this site.
http://www.g37-tech.com/wiki/Category:Service
Old Aug 2, 2008 | 09:01 AM
Xander's Avatar
Xander
Don't strip the wires at the amp if you don't need to. Just run a Line Level Converter from the rear speakers
Old Aug 2, 2008 | 10:50 AM
shepa's Avatar
shepa
ok so i found the amp in the trunk but have no idea which wires i need to splice into..... the service manuall posted earlier is a wierd 7z file??? never heard of it before and doesnt open up..... someone please helppppp me !
Old Aug 2, 2008 | 10:53 AM
EZDozzit's Avatar
EZDozzit
No Soliciting
PM me your email address and I'll email you the Audio section of the factory service manual. It's about 7Megabytes or so. By the way, 7z is another compression format similar to Zip files. You can find freeware on the internet to decompress 7z files.
Old Aug 2, 2008 | 11:10 AM
IP37's Avatar
IP37
check out page av-511 - 514 or so for bose amp inputs/outputs
wire color info is on GI-11...
B = Black
W = White
R = Red
G = Green
L = Blue
Y = Yellow
LG = Light Green
BR = Brown
OR or O = Orange
P = Pink
PU or V (Violet) = Purple
GY or GR = Gray
SB = Sky Blue
CH = Dark Brown
DG = Dark Green
When the wire color is striped, the base color is given first, followed by the stripe color as shown below:
Example: L/W = Blue with White Stripe
Old Aug 3, 2008 | 01:35 PM
shepa's Avatar
shepa
ok so i spliced the wires to the rear 2 speakers and now i need to know what wire i need to splice to connect to my amp as a remote turn on lead... the jl 1000/1 ampp needs a +12v power source to turn on the amp.... someone please help me so i can finnally finish this!
Old Aug 3, 2008 | 01:57 PM
Dieseldoug22's Avatar
Dieseldoug22
Sorry bud, but in order for that to happen you need to strip the wire at the amp and run your trigger off of that. If you have the service manual check for the woofer amp on signal. You need to splice into the #3 wire on the Sub Amp. I think it is Gray, whatever GR is.
You could have just gone to the sub amp in the first place and got the 3 wires that are needed instead of running 5 wires from different locations to make it happen. And no need for a Hi/Lo converter with the 1000/1. Awesome amp.
Old Aug 3, 2008 | 03:02 PM
shepa's Avatar
shepa
i spliced into the teh gr wire #3 woofer amp on signal and my amp still did not turn on ..... any advice?
blazeplacid
Sep 17, 2015 10:50 AM
lil_dave
Sep 2, 2015 11:49 AM
Dankleader420
Aug 25, 2015 06:14 PM
Christopher Dye
Aug 24, 2015 10:12 AM
cparise
Aug 19, 2015 01:51 PM
