NAVI PROBLEM or small mishap???
Old May 28, 2008 | 06:02 PM
NJlakeshoreG's Avatar
NJlakeshoreG
anyone have this problem??? my navi always worked no problem, i used it for the first time 2day since bout a week ago...it was stuck in the ocean and kept telling me to turn when i couldnt turn and useing the wrong streets...
i put in home 2 try the fastest way home from the shore 2day and this showed up makin me pissy 4 the ride home..lmao...i was in my driveway and it still showed up i was in the ocean over an hour away...wtf???it also said 23 miles 2 get home..lol...
i shut off the radio, i shut off the car...but still nuttin..im gunna try 2 use it again in a hour or so, to see if it works...
anyone have any ideas???
Old May 28, 2008 | 09:49 PM
bfranks's Avatar
bfranks
Check the GPS status. See how many (if any) sats you are tracking. If it's only 1 or 2 your PDOP will be sky high and more then likely the system won't accept the position. If you are tracking plenty of sats then it could be a problem with the VSS signal (nav won't update correctly if it's interupted).
Old May 29, 2008 | 12:42 AM
NJlakeshoreG
thanks bfranks..i was just messing with it and unclicked and reclicked some options and jsut goin thru the options and it finally came back 2 normal! but i have a feeling its gunna happen again
thanks for the input, i will remember this for next time!!
Old May 29, 2008 | 10:26 AM
bfranks's Avatar
bfranks
It sounds like a bad GPS antenna. If it happens again, take it to the dealer. They should be able to find the problem fairly quickly.
Old May 29, 2008 | 11:09 AM
xeddyboi420x's Avatar
xeddyboi420x
wow how wierd...
RYs06MT
Apr 22, 2016 11:00 AM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
Cmedlin96
Sep 20, 2015 11:09 PM
slawek65
Sep 8, 2015 09:07 AM
