power cord to trunk
Old May 23, 2008 | 05:07 PM
04STi208G37's Avatar
04STi208G37
I found this photo in another thread. This is where the wire goes. you will find this large rubber grommet at the base of the windshield on the passenger side , 9under the black plastic cover located just under the wiper blade.
Old May 23, 2008 | 11:01 PM
aznutx's Avatar
aznutx
thx, and this is big enough for a 2 gauge power cord u think? it's wut i have and i'd like to salvage since i remember it costing a bit per foot
Old May 24, 2008 | 07:55 AM
04STi208G37
Well the grommet you make your own hole. Under the grommet is a hard plastic holder of sorts. You will have to see if you can get 2 ga. in there. I was using smaller wire.
Old May 24, 2008 | 09:44 AM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
I didnt follow this route because I have 0ga. I actually didnt try that route cause I didnt see that. I wonder if it will fit big wire....
Old May 24, 2008 | 09:49 AM
aznutx's Avatar
aznutx
which route did u take max? cus ya 0, 2gauges are big, and from that pic, i dont know how big the hole is behind the rubber
Old May 24, 2008 | 09:59 AM
MaxToTheG37
umm... well... its hard to describe but here goes.... theres a grommit in the pass. side with a larg rubber tube in it... rubber tube is empty... no clue why its there.... but i fished the wire on the right side of the battery and it goes behind the front wheel well and found the hole and pulled it thru.....should be a lil easier with 2ga. let us know how it goes....
Old May 24, 2008 | 12:55 PM
aznutx's Avatar
aznutx
im still waiting 04STi208G37's info on the rest of the setup, cus it'd kinda weird having a huge power cord there and not knowing how to get it to the trunk haha
um can you see that grommit from the battery area? from the wheel well area if u peel back the liner?
Old May 24, 2008 | 01:08 PM
MaxToTheG37
no you cant... you have to pull the carpet up and then look from underneath the car to fish it to the hole...
Old May 26, 2008 | 09:29 PM
04STi208G37
Finished
I finished it today. After I got the wire in the footwell as described earlier, I went thru the passenger kick panel, down the passenger door sill, up by the rear side speaker and sort of under the seat into the and under the plastic spare tire surround and out by the jack. I connected to the battery with a fuse holder. No fuse until all is connected and grounded.
Old May 26, 2008 | 09:53 PM
MaxToTheG37
ok... i reran mine also today... ill post pics here in a bit... YES 0ga went through... w00t!
Old May 27, 2008 | 01:41 AM
aznutx's Avatar
aznutx
any pictures? but thx for the description should help me i think ima route it this saturday
vamarris
Dec 9, 2018 11:10 AM
ANMVQ
Dec 8, 2016 04:55 PM
Cmedlin96
Sep 20, 2015 11:09 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
