Music options
I think they are selling IPod Shuffles for $50 bucks. You might want to look into getting one of those.
Edit: Just saw that the Shuffles are only 1 to 2 gigs. If they allow you to create playlist then I would still recommend it over a CF card although the CF cards are cheaper.
For now...I'm definetely gonna get the SD Card to CF Adapter as it allows to keep my "all in one" device workin..if I did get an iPod in the feature, It'd probably be the iPod Touch 32GB
Just be aware that there is a limit on the number of files that the system will read (I think it's 512 for systems with nav / 999 for systems without). So you probably won't get to use the whole 4 gigs for music unless you get creative (whole albums as one mp3, etc).
I'm not sure you'd be able to use the iPod integration with a shuffle. The shuffle doesn't have a standard ipod plug, it has a completely different interface than other ipods.
I think the smallest one you could go for is the nano.
I use an iphone, but i'm thinking about buying a nano to just leave connected all the time.
You can use the RCA plugs and listen to it through the AUX mode on the stereo with a cable like this:
http://www.amazon.com/Apple-Audio-St...710168&sr=8-14
Traveling Administrator
Not sure if that's from the G37 manual or not, but if it is, it is a mistake. The G37 without Nav doesn't even get a CF slot.
